:droooooool:
Guest
Posts: n/a
http://www.tigerracing.com/cars/tiger-z100-main.php
The Tiger Z100WR as seen on TV (5th Gear with Tiff Needell breaking the world 0 -60mph record in a staggering 2.9 seconds in full road-legal trim.
The Tiger Z100 rear wheel drive Mk1 (with 510 bhp per tonne) as seen on TV Top Gear with Vicky Butler Henderson driving, this carburetor version's 0 to 60mph time is a staggering 3.1 seconds in full road-legal trim.
Tiger is confident that the 0-100mph and 0-100-0 times on the new Mk II Z100 will be staggering, even though never tested. so far we have not been invited to any of the tests organised by the magazines, maybe they know the outcome of having the Z100 in attendance!
The new MKII Tiger Z100 is fitted with twin Suzuki GSXR-1000 engines, which now give the Z100 600bhp per tonne and a lower finished weight that its predecessor, so it is expected to be quite a bit quicker.
The Tiger Z100 uses a modified R6 chassis; extra strength was needed in the chassis to take the phenomenal loadings due to the power and traction of the Z100.
Finish of the chassis and suspension is in powder coat, body work is as the R6 specification with main body in two pack paint spray finish to you colour choice, all wings are in carbon finish showing black weave, central tunnel and dash also are carbon finish.
The Suzuki GSXR-1000 bike gearboxes are used in the Tiger Z100, both driving into a bespoke transfer box. Sequential gear change is obtained through a split alloy gear lever mounted central tunnel; reverse is incorporated into the transfer box with a small alloy lever on right hand side of carbon tunnel.
The Tiger Z100 Mk II is only available as a factory built car and is priced at £33,000 excluding VAT, SVA and registration fees.
Specification
Model Type: Z100 chassis SA9Z
Chassis Type: 90% round tube spaceframe, powder-coated.
Body Type: GRP with carbon. Wings carbon.
Engine: 2 x Suzuki GSXR1000
Transmission: 6-speed bike gearboxes with bespoke transfer box.
Steering: Rack and pinion, 2.2 turns.
Brakes: Front 280mm disc with 6 pot calliper. Disc rear.
Suspension: Double wishbone front. De-Deon rear with adjustable shocks all round.
Weight: 550kg wet
Track: 1375mm
Rear: 1500mm
Wheel Base: 2230mm
Length: 3300mm
Wheels: 7inch x 15inch Alloy.
Tyres: Toyo race tyre. 205 front, 225 rear.
Specification
Weight: 550kg wet
Track: 1375mm
Rear: 1500mm
Wheel Base: 2230mm
Length: 3300mm
yes, cars...
besides that though....550kg is HEAVY for a race Se7en. The good road racing ones are on the order of 400 kg. Of course, this is in road trim, which would add weight.
I still like Sylvas and the other full bodied sportscar versions of the same chassis type.
-93 MR2, #129 ES
-93 MR2, #129 ES
Wait, doesnt the lingenfelter TT do 0-60 in 1.9? I guess that doesnt count?
ASE: Brakes
ASE: Brakes
