1,200 RWHP Out Of A Little Ole' Carb/Turbo Motor !
Guest
Posts: n/a
And look it is not even 350 cubic inches, I guess less can be more sometimes.
This guy built 95% of this car himself and on a very low budget.
Oh yeah it runs 8.12 @ 173.8 :o Carbs suck !
More pics. and info (it is the top car in the below link):
http://www.turbomustangs.com/redirects/featuredcars.htm
Turbo System:
Precision 98.5mm turbo
Turbonetics CO2 controlled wastegate
Air to water under dash intercooler
Engine and Management System:
347 CI built by Tyson
Dart block
Eagle crank and rods
Total seal rings
Erson cam
Twisted wedge Heads (CNC ported)
Induction and Fuel:
NON PORTED Victor Jr.
CSU modded blow through carb
CSU carb hat
Aeromotive pumps
Ignition and Exhaust:
MSD Digital 7 plus
MSD distributor
MSD coil MSD wires
Flipped BBK shorty headers
3" pipe from those to the turbo
5" muffler that exits behind the front right tire
Tranny and rear:
Powerglide
PTC convertor
8.8 rear end with all the goodies
Front Suspension:
Koenig struts
Custom tubular K member by Tyson
Rear Suspension:
Tyson uppers and lowers
Welded torque boxes
Strange double adjustable coilovers
Tires and rims:
Weld Pro Stars
28 x 10.5 MTs
Body:
87 Coupe
Custom Wing
Cowl Hood
Other:
Custom 10pt. chromoly cage by Tyson
Turbo System:
Dart block
Total seal rings
Erson cam
Induction and Fuel:
CSU carb hat
Aeromotive pumps
MSD Digital 7 plus
MSD distributor
MSD coil MSD wires
Tranny and rear:
Powerglide
PTC convertor
Front Suspension:
Koenig struts
Rear Suspension:
Welded torque boxes
Tires and rims:
Weld Pro Stars
28 x 10.5 MTs
Body:
87 Coupe
Custom Wing
Cowl Hood
Other:
gee...i wish i could put my intercooler inside the car
and that thing has more cubes then an LS1...so whats the "LS1 what?" comment about?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Guest
Posts: n/a
Most anything that is pushing 900 + rwhp and has a turbo gets a water to air inside the car these days. Come on you should know these things, or maybe not.
And I edited out the LS1 comment before anyone posted, I did not want to hurt any fragile feelings.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Guest
Posts: n/a
does air even get to it?
:o
