where to dyno
im still waiting to hear back from XAT on how dynojets numbers compare to mustang dyno's
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
so dynojets usually read higher than mustang dyno depending on application.
for example an rsx that puts out 300 on a dynojet may put down 260-270 on a mustang dyno
Green Eyed Princess Lover
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
Originally posted by jsimon9633
mustang dyno i believe puts the full load of your vehicle weight on the dyno and hence you will get a lower hp reading than on a dyno jet which only puts a certain load on the car ( i think its like 500lbs)
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
R.I.P Dad.
Originally posted by Boostin97SE-R
i was personally told from the xat people themselves that a mustang dyno reads alot higher than a dynojet
call coastal and they will back up what i said and they have a mustang dyno
but the only way to be sure is to get your car dynoed at a dynojet then immediately on a mustang dyno
i normally see lot lower numbers with a mustang dyno which would make sense if they are preloading the whole weight of the car rather than a set amount
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
ok just clarifying for jon and myself..we thought it odd that he lost such a large amount of power aswell as a couple others and when he told me they said that...i had to question certain things
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
i have never seen that happen
R.I.P Dad.
R.I.P Dad.
well cant tell ya! usually the mustang dyno SHOULD read lower cause of the above mentioned physics reasons
but of course a lot of things could of varied such as ambient temperature in the room and car condition so dunno.
that link to that article is usually the technical explanation why it reads lower than a dyno jet but not like i own both of them and know for sure.
if anyone dynoed last saturday at xat, maybe something was wrong with their machine? i dynoed at 150whp
stock type s is 165-170whp
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
i dynoed 239whp n xats and 273whp on Sam's. I was supposed to go to rev extreme and dyno there to compare but I no longer own the car. I sold it and it is now in Ohio.
R.I.P Dad.
R.I.P Dad.
'99convGT
'99convGT
