Which Compressor?
Posting for SLOWY
What size/hp compressor and tank would be the best for home use. i know nothing about compressors, so i need to know what the best size would be. i've heard that small tanks with low hp compressors wouldnt be enough power, but what would be the smallest size/hp i could use? Thanks in advance
Guest
Posts: n/a
4ll d3p3|\|d5 0|\| \^/h47 y0u 4|23 g01|\|g 70 u53 17 f0|2
l1gh7 u53 4 f1v3 g4ll0|\| 74|\|k 15 f1|\|3
m3d1um u53 10 g4ll0|\| 0|2 1f y0u h4v3 7h3 5p4c3, 15
Much b1gg3|2 7h4|\| 7h47 15 g01|\|g 70 g37 b1g, 4|\|d 3><p3|\|51v3, qu1ckly, 4|\|d |\|07 m4|\|y |\|31ghb0|2h00d5 \^/4|\|7 70 l1573|\| 70 7h3m
normal basic car work, its an apt garage so i can't have something loud and
constantly running
what kinda prices are the 10 gals ?
does the HP on the compressor make a difference? if so, how?
slowy
constantly running
slowy
If someone is just going to infrequently use power tools and blow stuff off sometimes even a nitrogen or CO2 tank with a regulator/warmer is more practical.
If you need some compressed air on the side of the road its a lot more portable too.
if your doing alot of work, get a 15gal....it will go longer between the motor kicking on...i tried using a 5gal with an impact and it was on like every minute or two. the one at the shop is 15hp( i believe) and 80gal and is LOUD when it starts to compress.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
30 gal, 6 hp... It blows my car dry REAL quick at 150psi!
