Porsche GT2 at Chili's/Windy City Pizza
I've only seen like one other GT2 around town (and it was parked in Reeves, getting ready for some crazy upgrade...I forgot what the guy said they were doing to the car). That's why it caught me off guard. And they're not AWD like the regular Turbo, they're RWD. I still haven't seen a GT3 in Tampa.
The one I saw didn't look like the GT2 in those pictures (didn't have the aftermarket wheels or front).
The top picture is a Twin Turbo - not a GT3
GT3:
Rear-mounted, 3.6 liters, 6 cylinder, rear-wheel drive, two-seater, coupe
MSRP: $99,900 (USA)
MSRP: $139,000 (CAN)
380 hp @ 7,400 rpm
285 lb-ft @ 5,000 rpm
0-62 mph: 4.3 sec
Top Track Speed: 190 mph
City: 15 mpg
Highway: 23 mpg
The new 911 GT3 is powered by a water-cooled flat-six featuring four-valve heads and VarioCam variable valve timing. One of the most accomplished naturally aspirated engines we've developed for the road, this compact unit features ultra-lightweight titanium connecting rods, a dedicated oil-cooler system and dry sump lubrication with an engine-mounted tank.
The engine is located behind the rear axle-line in the traditional 911 position. The total displacement of 3.6 liters is good for 380 hp at 7,400 rpm, or an extremely high specific output of nearly 106 hp per liter of cubic capacity.
Maximum torque of 285 lb-ft is available at 5,000 rpm, while the maximum engine speed runs to 8,200 rpm depending on gear selection.
The result is an engine that not only sounds good on paper, it is also capable of delivering the high performance and distinctive tone of the 911 GT3.
Key characteristics of the GT3 engine include optimized cylinder charging (thanks in part to VarioCam variable valve timing) as well as exceptional balance of all moving masses ensuring cultured performance at all times. The ultra-lightweight titanium connecting rods and weight-optimized pistons help minimize the oscillating masses in the engine, thereby enabling a more dynamic and immediate response. The valve gear also benefits from Porsche race engineering. The new lightweight valves, for example, are actuated by means of self-adjusting tappets that are 42% lighter than the previous generation of components. By minimizing inertia in the valve gear, the engine can rev to between 8,000 and 8,200 rpm depending on gear selection. This in turn enables a closer ratio gearbox offering much faster acceleration.
Air is supplied through a new lightweight manifold featuring shorter tubes and optimized inlet ports. Both inlet camshafts use VarioCam adjustment to achieve optimum exhaust, torque and power characteristics based on current engine load at all engine speeds.
For the driver, the result is a more immediate response to even the lightest throttle input, as well as phenomenal reserves of power and torque, and a breathtaking sound from intake and exhaust that's driven by the high-revving engine. In short: all the characteristics you'd expect from a racing car in a package that's equally at home on the road.
GT3:
MSRP: $99,900 (USA)
380 hp @ 7,400 rpm
0-62 mph: 4.3 sec
City: 15 mpg
Highway: 23 mpg
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
-Mark Donohue
Originally posted by TheShow50h
Thanks for the specs.
+1 very nice car, i'd love to put a hurtin on one
TR stranded on an island with plenty of nugs crew #001
TR's happily, finally married crew #003 (and not to a stripper this time
TR's nugs crew leader #001
originally posted by everyone on tr:
"I hate Goopster with all my internet hating capabilities...thats why I use his email to sign him up for child porn"
What top picture?
GT3:
MSRP: $99,900 (USA)
380 hp @ 7,400 rpm
0-62 mph: 4.3 sec
City: 15 mpg
Highway: 23 mpg
GT3:
MSRP: $99,900 (USA)
380 hp @ 7,400 rpm
0-62 mph: 4.3 sec
City: 15 mpg
Highway: 23 mpg
I assumed this is what he was talking about
Originally posted by marKo
i know a doctor friend that has one, tryed to get him to put some money on a race(at the track), but he declined
Now here's a picture you don't see that often... Juan Ruiz - South Florida - he'd run you...
