Auto Trans shifting problem
Old Mar 22, 2004 | 06:35 PM
TaMpAToNy69's Avatar
Hey You! Stay Gay!
Default Auto Trans shifting problem
Alright first off I'm more familar with rotary engines than piston engines and not too fond of automatics so I don't deal with them much. with that said hears the problem.
I have a friend with a 92 grand am 3.3 liter V6 3300 series motor with an automatic transmission. First we had a head gasket blow and that caused a huge problem with coolant in the cylinders. so much coolant in the engine that the pistons could not reach the top of the cylinder during compression and with that stress caused the crank shaft to break. I know what u are thinking this doesn't happen or if it does it doesn't happen often. I have had a couple mechanics look at it and they all agreed.
After that problem we bought another engine from brandon auto salvage with 64000 miles on it. I did the swap and now the trans. is acting wierd.
When i go over a speed bump or turn after declerating the car acts as though it was switched into neutral for a few seconds and the gears don't seem to catch. Has anyone ever had this problem? Or does anyone know how to fix this problem? Does it have something to do with the flywheel and torque converter? I was thinking maybe the screws that connect the two aren't torqued to the correct pressure.
Any advice or comments that could help come to a solution for this pain in my ass are much appreciated.
Thanks in advance,
Tony
Old Mar 22, 2004 | 07:13 PM
Tits McGee's Avatar
is cooler than you
does it have fluid in it?
Old Mar 23, 2004 | 03:57 AM
DebianDog's Avatar
N2O Lover
Did ou port or descreen the MAF? K&N filter? Anything to change the air intake, like that?
Debian Dog
2001 Trans-Am - A4 w/2.73 Steel Driveshaft - Full weight
2004 SRT-4 - MPx, PSI intake
Best Times 1/4
N/A - 12.56@110.51
N2O - 11.43@123.15
100 shot
See My Cars - Listen to the 224/228 closed & open - My Latest Video of Drag Run
Originally posted by moldyhands
Show me an 11 second import that only has a few thousand in it, and I'll show you a car owner that's always talking about when his car's going to get fixed and what broke.
Old Mar 23, 2004 | 06:05 AM
Hey You! Stay Gay!
Yeah it has fluid i added fluid to it after it lost alot due to the di[p stick and housing being removed
no i didn't port anything out or mess with the intake in anyway the cars stock its a POS i dont want to deal with anymore after i find out whats wrong with the shifting
Tony
