Fineshed custon 3" dual exhaust with X pipe and Tq arm/brace
Old Feb 21, 2004 | 09:49 PM
HybridSS's Avatar
I have fuzzy eyebrows
Default Fineshed custon 3" dual exhaust with X pipe and Tq arm/brace
About 100 man hours of work right there!
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Feb 21, 2004 | 10:08 PM
Dead Hooker's Avatar
Default Re: Fineshed custon 3" dual exhaust with X pipe and Tq arm/brace
[i]Originally posted by HybridSS
About 100 man hours of work right there! [/B]
Good thing you helped for 2 or 3...........
Old Feb 21, 2004 | 10:19 PM
HybridSS's Avatar
Mars...I know the F body/Tq arm suspension is tough to understand....believe me I know..lol.
Basically the drive shaft loop was just integrated into the Tq arm mount. It doesnt do much except try to contain the DS if it should snap.
The important stuff is basically the bar to the left of the drive shaft...its the Tq arm. Its mounted to the rear end. It does a few things. When you launch hard it will transmit the twisting force of the rear to that fwd mount...pushing up. This helps transfer weight to the rear by lifting the front. It can be a considerable force. The Tq arm aslo is used to adjust pinion angle for the rear U joint. Keeps the DS and the yoke on the rear end aligned. The Tq arm now has 5 adjustment points on the front mount. That will change how the force is transmitted.
The other thing about this setup...is it takes the fwd Tq armattach point off the tranny. The stock piece is attached to the tranny on a weak aluminum mount. The stock Tq arm is also just a weak stamped steel piece. MIne is now chrome moly. The cross brace is tied into the subframe connectors. Cross brace is stainless steel.
All in all that Tq arm should be strong enough for low 9s high 8s easy.
Old Feb 21, 2004 | 10:23 PM
HybridSS's Avatar
Default Re: Re: Fineshed custon 3" dual exhaust with X pipe and Tq arm/brace
Well..when you are the boss...you get away with that....now get back to work bitch
Old Feb 21, 2004 | 10:53 PM
HybridSS's Avatar
No... your seeing it right. But the DS will not move that much. I have poly engine mounts and tranny mounts that move very little. If it moved so much that the DS hits the loop...something else would be broke. There is alot of clearance there.
And now that the TQ arm is no longer mounted to the tranny...the tranny moves very little under a hard launch.
This is similair to the BMR extreme Tq arm or the MADMAN racing set up. Except thiers will not work with true dual exhaust. And ours is quite a bit stronger.
Its all basically tied together now and is very strong. Cant ait to test it at thwe track
Old Feb 22, 2004 | 04:21 PM
0HP930's Avatar
Guest
Thats nice and all, but at 100 hours your either counting the beer drinking and looking at stuff time or someone is milking that job.
Old Feb 22, 2004 | 04:50 PM
Bill's Avatar
Livin' in Seattle
Not really. Most of the time probably went into measurement and pre-fab. That's always a pain in the ass. Give me a damned blueprint anyday.
Al...your car scares me.
