honda engine vs nissan engine
Old Jan 31, 2004 | 05:54 AM
type-j-spec's Avatar
Default honda engine vs nissan engine
SR20DET U12
2.0 DOHC 16V Turbo 205 HP Nissan Motor. Fits 95+ 200SX/Sentra. Please consult with a mechanic for any other fitments or necessary parts. Includes engine, trans, and turbo.
Engine & Trans for $1295.95
SR20DET S13 Red Top Front Clips
2.0 DOHC 16V Turbo Nissan Motor. The S13 Fits 89+ 240SX. Rear Wheel Drive Configuration. Please consult with a mechanic for any other fitments or necessary parts.
S13 Red Top Half Cut (Front Clip) for $2195.95
RB25DET R33 Skyline
2.5L DOHC Turbocharged Nissan motor. Note: This motor Requires custom work to put in but can be made to fit S13,S14, or 300ZX. Includes the whole front clip (no body parts) including everything in the engine bay. Please consult with a qualified swap mechanic.
RB25DET- R33 Half Cut (Front Clip) $2695.95
VS
B16A (1.6 DOHC V-TEC) 160HP
1.6 DOHC 16V VTEC 160HP Honda motor. Direct from Japan. Includes engine, cable transmission and ECU (For 88-91 Civic/CRX & 90-93 Integra). Can also be adapted for use on 92+ vehicles with hydraulic to cable adapter and wire harness adapter.
Engine, Trans, ECU, Harness, Axles, Shift, Linkage and Mounts for $1495.95
B18C (1.8 DOHC V-TEC) GSR
1.8 DOHC 16V VTEC 178HP Honda motor. Direct from Japan. Includes engine, transmission and ECU. Direct bolt in for 94-01 Integra and 92-00 Civic. OBDI and OBDII available.
Engine, 5spd, ECU, Harness, Axles, Shift LInkage, and Mounts for $3495.95
Engine, Auto Trans, ECU, Harness, Axles, Shift LInkage, and Mounts for $2295.95
B18C5 (1.8 DOHC V-TEC) Integra Type R
1.8 DOHC 16V VTEC 197 HP Honda motor. Limited production race motor direct from Japan. Includes engine, hydraulic transmission and ECU. Direct bolt in for 94-01 Integra and 92-00 Civic.
Engine, Trans, and ECU for $4995.95
i think i know why but i would like to get peoples opinions on the price and performance difference between honda and nissan engines(specialy the price)
Old Jan 31, 2004 | 06:28 AM
F4A22's Avatar
Old School
Why dont u just see the light and do this.
4g63t(2.0 DOHC TURBO)Comes in many cars and has been used for over 10 years.210hp out of the box and kicking most ass to this day.Oh and no need to swap it in it comes in alot of u.s sold cars to date.
Old Jan 31, 2004 | 07:45 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
You keep encouraging this, just wait until your shit blows up, you'll be singing a much different tune.
Old Jan 31, 2004 | 07:57 AM
Whaazup17's Avatar
or see this godly light
450 HP @ 5250 RPM, 550 FT.LBS of Torque @ 3500 RPM (Max. Recommended RPM: 5500)
8.75:1 Compression Ratio
all for $5525.99
-garrett
Old Jan 31, 2004 | 09:44 AM
vertigo_16201's Avatar
all for $5525.99
-garrett
I need to figure out hwo to get 1 of those into my honduh.
Old Jan 31, 2004 | 01:48 PM
Topless T/A's Avatar
Voice of Reason
all for $5525.99
-garrett
yes.......end of discussion
Assemblage 23
Negative Format
I'll work to elevate you, just enough to bring you down.
Old Jan 31, 2004 | 02:54 PM
sentra of attention's Avatar
Jose
werd!!!
Old Jan 31, 2004 | 03:01 PM
Jose
Default Re: honda engine vs nissan engine
hondas are almost a drop in away from ready to drive and fits in most models on hondas which is a +1!
w/ nissan sadly i prolly cant swap that sr20det u12 into my 04 sentra...hmmm unless someone here know if it fits w/o much costosmizations.
Old Jan 31, 2004 | 03:42 PM
F4A22's Avatar
Old School
You keep encouraging this, just wait until your shit blows up, you'll be singing a much different tune.<<< vito pendejo
Shit breaks when ur going fast.So i guess ur slow.
