Well.....
its still on Stock internals, block, head, tranny, axles, mounts and clutch for now. Its an AGP turbo kit which features a T3/T4 hybrid, i'll link the specs here in a sec..i totally agree with you Zate. SRT4s are gonna become the FWD "Supra" ...not something im happy to say but its the truth, im never affraid to admit the truth.
scenario
400whp SRT4 owner : "hey wanna run?.."
03 Cobra owner : "lets do it from a dig.."
400whp SRT4 owner : "i cant hook, lets do a 40mph rollon.."
oh well
scenario
oh well
"if you got turbo lag, you ain't drivin' it right!!!" -Carroll Shelby
Skittles.....tasty arent they?
Try the newest flavors yet?...Orange blast and white mint
I specialize in SRT4 tuning/troubleshooting/repairs.....
The factory TD04LR-15GK-6cm turbocharger is...well, let's just say it gives us the opportunity to improve the turbocharger design for the 2003 and up SRT-4. The integrated manifold and turbine housing design, along with the reversed rotating blades, does not lend an easy turbo upgrade path. We can upgrade the stock compressor wheel to a reverse rotation 16G and machine the compressor housing to fit the larger wheel. However, with an upgraded compressor wheel the exhaust manifold pressure to intake manifold pressure ratio soars past 4:1. Modifying the TD04L turbine wheel (clipping) brings the ratio down closer to 3:1, however you are reducing turbine efficiency, and a 3:1 backpressure ratio reduces the engine's volumetric efficiency tremendously. Let the 2.4 breathe!
Fast-forward to today. We have developed a complete replacement manifold, turbocharger, external wastegate, and O2 housing kit that will allow for endless possibilities. Whether you are into drag racing, road racing, autocross, or stoplight-to-stoplight performance, we can build a setup custom tailored to your needs.
This kit starts off with a new exhaust manifold centered around the Garrett T31 High Flow 4 bolt outlet turbine housing. Turbo placement is a key variable in this design, because of the clearance with the engine and firewall. Rest assured, the centerline placement of the turbocharger allows for enough room so you DO NOT have to "convince" your firewall. NO DENTING OR HACKING OF THE FIREWALL NEEDED with our kit.
Base Price - $1700 - Includes: AGP T3 manifold, TiAL 38 or Turbonetics Deltagate Evolution wastegate, dump tube, 57 trim or 60 trim T04E compressor/ 76 trim T31 turbine, 2.5" to 3" O2 housing, oil feed and drain lines, gaskets, nuts and bolts, ss heatshield, overflow bottle. Available turbine housings - .48, .63, .82, 1.06 A/R ratios. Optional turbine wheels - 76 trim T31, 76 trim T350, O trim T4, P trim T4.
Options:
60-1 T3/T4 - $75
50 trim T3/T4 - $100
56 trim GT40/T350 (AGP61) - $100
NEW - 44 lb/min GT25BB in a .48 or .63 A/R turbine housing - $500
NEW - 52 lb/min GT30BB in a .63 or .82 A/R turbine housing - $500
55 lb/min GT30BB in a .63 or .82 A/R turbine housing - $500
60 lb/min GT30BB in a .63 or .82 A/R turbine housing - $550
65 lb/min GT30BB in a .82 or 1.06 A/R turbine housing - $600
Polished Compressor housing - $100
Options:
60-1 T3/T4 - $75
just for comparison, the overlay is that of your everyday SRT4
Guest
Posts: n/a
M4k1|\|g p0\^/3|2 0|\| 7h47 m070|2 15|\|'7 h4|2d. 7u|2|\|1|\|g f457 3/7'5 15. 7h47'5 3|\|0ugh \^/hp 70 |2u|\| 11'5 \^/17h 3453. 5h0\^/ m3 50m3 71m3 5l1p5 4|\|d 7h3|\| \^/3'll 74lk 4b0u7 1mp|23551v3.
1f 0|\|ly 7h3y \^/3|23 5m4|27 3|\|0ugh 70 m4k3 7h47 c4|2 |2\^/d 7h3|\| y0u'd h4v3 4 m0|\|573|2 0|\| y0u|2 h4|\|d5. H3|\|c3 \^/hy 1 571ck \^/17h 240'5
...i hope he put a limited slip in that thing....only thing i can see that car doing well is taking left hand turns.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
its an 03 and an LSD will see duty here soon, the owner seems to have deep pockets...then again who doesnt in houston..
