side markers
Do these replace your stock ones? If so, aren't they bolt-on? If not, then you will need a body shop to put them on probably I guess. If they just bolt on or screw on, then you should be able to do them yourself though.
You can install them yourself in your driveway. If you don't see any screws or bolts, they are probably the snap in type. You will need one flathead screw driver, five minutes, and three brain cells. best of luck to you.
Originally posted by marcusscott
I got some side markers i need put on a 95 civic. Anyone know where i can get them installed?
"The genius of any slave system is found in the dynamics which isolate slaves from each other, obscure the reality of a common condition, and make united rebellion against the oppressor inconceivable." ~Andrea Dworkin
"If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law." ~Henry David Thoreau, 1849
That's right, bitches, TWO quotes!
