Unorthodox engine break-in
Old Nov 5, 2003 | 09:40 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Default Unorthodox engine break-in
The page seems to be tied into selling some sort of e-magazine, "power news" or something like that, but the content seems to be legitimate, even if possibly wrong.
http://www.mototuneusa.com/break_in_secrets.htm
This "full throttle" break in method goes against everything I've been taught when it comes to the first 1000 miles of a car's life. I remember interstate drives at 55 and eggshell gas pedal techniques when I first drove my dad's 02 accord. Now this guy says to give it some gas and let it rip to promote engine life and even ring wear?
What do you guys think?
Old Nov 5, 2003 | 10:30 PM
Slash's Avatar
THE HAMMER
the first time a motor (read this as new block or motor straight from the factory) is run... you should take lots of time to ease it in because the heat cycling is changing things inside of it.. this cycling is necessary for the engine to reach proper sizes and clearances internally for smooth operation..
With a rebuilt motor, everything (or most everything) that is in the motor (or rather the block) has already been heat cycled, and after a very short time it is fairly evident if the rings have been seated or not.. at this point using this "full throttle" method is acceptible and possibly better.
I dont feel like a sig today.
Old Nov 6, 2003 | 12:48 AM
craig_302's Avatar
boostmonkey
Hahah, this is way before everyone who has posted in this thread, but we had a term for that kind of engine break in technique: Moneygreen'd.
Old Nov 6, 2003 | 04:55 PM
Levi's Avatar
I think its stupid to run a engine hard before its had 2500..It almost like running a engine hard while its cold, you get the same effect.
I built a 2.3 Ford back in 1987 and I did the 500 mile break in, worse mistake of my life. I would never recommend any less than 2500 miles and in that amount of miles, 3 oil changes.
custom parts is our perfection.
Old Nov 6, 2003 | 07:57 PM
2TurboImports's Avatar
sooo...where's the turbo?
no offense...but then you probably didn't build it correctly?
Old Nov 6, 2003 | 08:59 PM
20v vdub's Avatar
I belive break it in Hard...Im not saying to go out and slam gears.
But not to be afraid to push the limits...
