whats the purpose of camber's?
Old Oct 8, 2003 | 11:39 AM
lowoctane's Avatar
Professional Dumbass
Question whats the purpose of camber's?
just wondering what they are?
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Oct 8, 2003 | 11:59 AM
suprapimpa's Avatar
Do you mean camber kits, if so there to help correct excessive camber when you lower your car. If not try to be more specific and maybe I can help you
Old Oct 8, 2003 | 12:50 PM
TampaWRX's Avatar
danse
Originally posted by SupraKid
camber is just the angle of the tire relative to the road surface. If the tire is standing straight up, that's zero camber, if it leans in toward the car, that's negative camber, and if it leans out, that's positive camber. It is an ironic twist of language that negative camber is what you want, and positive camber is what you should avoid at all costs.
you want a camber curve that keeps the tire straight up and down when you are driving straight, and leans the tire in slightly (1 to 2 degrees of negative camber) during cornering. this goal is nearly impossible to meet, but some suspensions do come close.
You can actually achieve this effect with caster adjustments. The control arm bushings in my car increase caster on a very limited basis, but more aggressive bushings are available. Racecar tech=good.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
Old Oct 10, 2003 | 08:27 AM
Whaazup17's Avatar
i set my camber up for my kart. and then you have toe in and toe out. and you have caster and then you have your weight distruibution your nose your cross which is left front +right front / right rear i belive..... (im probably wrong)
