Question
Old Sep 9, 2003 | 06:19 PM
racethis001's Avatar
Shake & Bake
Default Question
Can i use a power inverter to power a shop and a steam cleaner? not at the same time of course.
Old Sep 10, 2003 | 02:29 PM
0HP930's Avatar
Guest
Are you talking about for running 3 phase equipment on 2 phase power or for DC to AC conversion?
Either way, anything is possible as long as the converter and power source is rated for the load you will put on it.
Old Sep 10, 2003 | 08:13 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
I don't know about that. I tried to run a 13 inch tv and a dvd player off of an inverter at the same time as having my radio on and it just instantly blew a fuse somewhere down the line. I think the inverter was rated for it, just barely, but the power line to the cig lighter must not have been.
Old Sep 10, 2003 | 08:38 PM
Guado's Avatar
What can Brown do for you
you would need a BIG(read $$$$$$) inverter. Those things draw mad amps/wattage
however more than likely a generator is gonna be your only option.
-Eddie
Old Sep 11, 2003 | 09:30 AM
perdition79's Avatar
Grift Consultant
make sure you're using at least a 1200 watt inverter, keep the car running, and make sure the water levels in your battery are topped off. and if the items don't work well, you're putting an inductive load on the inverter, which can be corrected by plugging a small lamp, low wattage, into one of the empty plug sockets.
oh yeah, and pray that you don't screw up your alternator.
"The genius of any slave system is found in the dynamics which isolate slaves from each other, obscure the reality of a common condition, and make united rebellion against the oppressor inconceivable." ~Andrea Dworkin
"If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law." ~Henry David Thoreau, 1849
That's right, bitches, TWO quotes!
