quick question on engines
Old Sep 2, 2003 | 06:28 PM
SPLATT's Avatar
TONIGHT....YOU....
Question quick question on engines
ok, here we go. i found a block (8.2L) and was plannin on buildin that to throw it in the monte. but earlier today i was lookin at some prochargers and i thought "hey, you got a perfectly good small block with a little over 400 ponies and less than 10K mi" and BOOM! it hit me. so my question is...should i stick with the massive yet expensive torque monster....or put my thought into motion and supercharge the 358(also, any supercharger suggestions would be appreciated), and on top of that add a new trans and heads for much cheaper?
"My CaR Are SlOW"
1985 monte carlo SS *under construction*
2002 T/A Firehawk #0490. M6. A few RWHP/ more RWTQ.
Old Sep 4, 2003 | 11:52 AM
BlackZ28's Avatar
ppssshsshhhhhhh
go with the sbc. the 8.2 is gonna cost A LOT MORE in the long run. but if u want to make the local gas stations earn a lot more money, get the 8.2 the 8.2 is also gonna bring up some streetability issues.
Old Sep 4, 2003 | 04:08 PM
flyinbrian's Avatar
There is no replacement for displacement.
The only streetability issues I can see with the big block is the 9 mpg cutting your range on one tank down.
IMO-If there is room for a big block, bolt one in.
Unless you plan on autocrossing the car, (which a good friend of mine autocrossed his BBC powered 78 Malibu), the big block is the way to go.
The bonus to the cubes is, you can build a monster running on the cheap pump gas with a pussy cat idle and have loads of torque.
Another positive-Leave your car alone, build the big block while you still enjoy your car, (since it is still running and not in pieces getting a supercharger added). Once ready to install the big motor, pull the small block, sell it, re-coupe some costs, turn key..enjoy stump pulling torque!
BTW- Your SS has the perfect stance. I always hated how they seem to ride nose up/rear down in stock form. It ruined their look. Yours looks perfect. +1 on the Convo-Pros too.
Old Sep 4, 2003 | 04:25 PM
StuntMan's Avatar
Driver
Put a s/c on the big block. If it is a car you drive often I would say go with a supercharger. If you have an auto I would put a twinscrew on it. If you are going to go with a centifugal supercharger Vortech is the best when it comes to reliablity and service but they tend to make alittle less power. I have heard lots of bad things about Powerdyne's. If you put a big block in you are going to add weight in the front of the car making it handle a little worse and you are going to have less space to work with when you need to work under the hood.
If speed kills then I'm suicidal
Old Sep 4, 2003 | 06:37 PM
SPLATT's Avatar
TONIGHT....YOU....
sry man, she aint mine , but i do have similar wheels, and mine is dropped a little in the front (not quite that much). i figured since i dont have a scanner, ill just put the baddest one i can find on there.
"My CaR Are SlOW"
Old Sep 4, 2003 | 06:45 PM
SPLATT's Avatar
TONIGHT....YOU....
hmm thats a good idea mars. ive never had much experience with EFI, and i was wonderin what the switch would consist of, and if it would be a pain in the ass or not. oh yea, and would it be too pricey?
thnx for the idea mars
"My CaR Are SlOW"
Old Sep 4, 2003 | 07:42 PM
SPLATT's Avatar
TONIGHT....YOU....
hmm sounds pretty easy. if i do supercharge it, what kinda compression would be best, since im changin the engine a lil anyway
"My CaR Are SlOW"
