NX Here I come!
Old May 21, 2003 | 10:37 AM
vetkilr's Avatar
04 Cobra man
Default NX Here I come!
Well after all the awesome reviews about my porting the M-90 I have and talking with SAM of the famous or infamous Coastal Place,Ive decided to go with a small shot of Nitrous
Im getting a NX kit either new or used?Im talking to someone now about a used kit with all the goodies!
Let me know what you think safty wise is nessasary!
Heater
Purge
Window switch
bottle opener
etc............
JOEL
Old May 21, 2003 | 11:43 AM
NitroGlycerin's Avatar
World Skee-Ball Champion
A/F ratio, fuel press., bottle temp/press. gauges...
EDIT: Oh, and -2 copper plugs.
'99 GT 35th Anniv - 13.01 @ 107.4 w/ cams & bolt-ons - Sold
'03 Audi A4 1.8TQ - :gordy:
► Home Buying & Selling Finance Tips ◄
[/b]
Old May 21, 2003 | 11:53 AM
Modular Matt's Avatar
200 SHOT
vetkilr you put some spray on it and you might be able 2 hang with me
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old May 21, 2003 | 02:34 PM
vetkilr's Avatar
04 Cobra man
Thankx anymore?
JOEL
Old May 21, 2003 | 07:36 PM
BLUE2KSS's Avatar
Mechanical Engineer
retard the timing 2 degrees per 50 shot. when i do it, i am getting the msd digital 6 ignition box so when i spray, it will retard the timing when the system is activated. the msd 6al doesnt have the timimg retard feature, so if you take this advice, you must use the digital 6.
Old May 21, 2003 | 07:38 PM
Strokd85's Avatar
Daddy-O
purge is good to have, bottle heater as well (doesn't have anything to do with safety though), but will help keep the pressure where you need it.
make sure the blow off valve works.....
I am your penalty.....
Old May 21, 2003 | 08:54 PM
bitemark46's Avatar
Got traction?
Why do u wanna put another power adder on the car? Is it just rwhp your looking for or lower ET's? More power won't always mean better ET. IMO one power let alone 2 isn't ideal for those hypereutectic pistons. They melt like butta! -Mark
98' cobra
Old May 22, 2003 | 04:00 AM
vetkilr's Avatar
04 Cobra man
If I could put three poweradders on it and have a nice tune I would
I need to cool down the Discharge temp of my blower.The car pulls 6 degrees of timing once it reads the temp getting hott thus kill 30-40rwhp.My times are suffering since the winter is gone.Plus now that I added a smaller pulley it gets really hot the water in my little pathetic stock tank was 122 degrees just driven around the other day.I got this info from Rick at Amazon Racing he knows Cobras and Ford pretty much just took the Roush design and put it on the Cobra.
But me and Sam are going to do a couple of things to get the water temp down also:o
JOEL
