Fordspeed price quotas plz! (Tony)
How much to install nitrous on 97 gt? Get a 255lph fuel pump and installed too. Thanks
I'd just give them a call, I know Joe is very busy so he might not see this right away..
Ok, I might do it myself only if i have everything needed. I havnt got the kit yet but I will tomorrow I hope.
what kit did you get .... brand and model?
How big of a shot are you gonna run?
its NOS the dry I believe, probably a 75. I dont wanna install it untill I get a good tune or something.
Originally posted by Hondahunter97GT its NOS the dry I believe, probably a 75. I dont wanna install it untill I get a good tune or something. |
Thats all true except... I wouldnt want to run only 1 pump, if that pump takes a shit when your on the juice... you now have a bomb under your hood lol, at least get a backup/ secondary pump. Just my .02
Originally posted by N20D5OH You can tune it yourself, dry kits are easy. Put the kit in, go to a step colder plug and gap them a little tighter. Pull 1.5-2 degrees of timing for every 50 hp of N20 you're going to run. If you're only running a 75 shot your stock fuel pump should be fine, if you run bigger you'll need at least a 190lph. You'll also need an adjustable fuel pressure regulator and turn up the fuel pressure with the vacuum off to about 40psi. After that, let it rip! :) |
[QU073][1]0|21g1|\|4lly p0573d by h3|2|2c0m357|20ubl3 [/1]
7h475 4ll 7|2u3 3><c3p7... 1 \^/0uld|\|7 \^/4|\|7 70 |2u|\| 0|\|ly 1 pump, 1f 7h47 pump 74k35 4 5h17 \^/h3|\| y0u|2 0|\| 7h3 ju1c3... y0u |\|0\^/ h4v3 4 b0mb u|\|d3|2 y0u|2 h00d l0l, 47 l3457 g37 4 b4ckup/ 53c0|\|d4|2y pump. Ju57 my .02 [/QU073] 1|\|c0|2|23c7. 1 \^/0uld MUCH |247h3|2 h4v3 0|\|3 pump f0|2 |23l14b1l17y. |\|17|20u5 15 |\|07 c0mbu574bl3 \^/17h0u7 fu3l. 7h1|\|k 4b0u7 17: 1f y0u h4v3 7\^/0 pump5, y0u 7u|\|3 7h3 |\|17|20u5 f0|2 5uch 4 537up, c0|2|23c7? \^/h47 h4pp3|\|5 \^/h3|\| 0|\|3 0f 7h3 7\^/0 pump5 g035 0u7? L34|\| c0|\|d1710|\|, bu by3 m070|2. 7h47 53c0|\|d pump 15|\|'7 g01|\|g 70 k|\|0\^/ 70 p1ck up 7h3 5l4ck. 54m3 5c3|\|4|210, bu7 \^/17h 0|\|ly 0|\|3 pump? 1f 17 g035 c0mpl373ly, y0u'|23 much m0|23 l1k3ly 70 |\|071c3 17, b3c4u53 y0u \^/0|\|'7 b3 g01|\|g 4|\|y\^/h3|23. 1f 17 d035|\|'7 m4k3 53|\|53, bl4m3 17 0|\| |\|yqu1l 1 \^/1ll :D |
