Suspension Advice
Old Mar 4, 2003 | 09:51 AM
Toma's Avatar
Ricer In Training
Question Suspension Advice
I need advice from people who have played around with Fox suspension. I have upper and lower arms and subframes. Right now I'm debating between 90/10 and 70/30 for the front, some people have gotten a lot of floating from the 90/10's and definitely 50/50 for back(drag radials). Thought about traction bars too. Don't care that much about handling,(although body roll sucks), wanna get the rear to hook up better I wanna a spend around $500
So if there are certain brands that you liked, or you've had had good experiences with certain products - post away.
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Old Mar 4, 2003 | 07:03 PM
Strokd85's Avatar
Daddy-O
ok.
just so you know what I run...
lakewood 90/10s up front 50/50s in the rear (CE 3 way adjustables)
trick springs up front cut to the desired length
normal 8 cyl springs in the rear.
i've gotten consistent 1.39, 1.40 60' times with this combo.
i've got CE lowers and single adjustable uppers..
all of the lowers function the same, although as Dave stated with the SS bars changing the intersect points, you have to be carefull. Plant the tires too hard and you'll end up unloading the suspension and you'll just go up in smoke...
probably going to be looking to get rid of the 90/10s and 50/50s as I will be going to adjustables all the way around..
I am your penalty.....
Old Mar 5, 2003 | 08:21 AM
Toma's Avatar
Ricer In Training
Originally posted by FordMan
What kind of upper and lower arms do you have ?
Don't know what brand, bought'em with the car, don't think they're adjustable.
Old Mar 5, 2003 | 12:51 PM
T/S #25's Avatar
Need To Get Quicker
Watch any type of solid bushing control arm, be it either the uppers or lowers, if you drive the car on the street a lot. You will need to keep them greased and after time, the bushings will eventually wear out. You might want to look into something with some poly bushings like the Mega Bite Jr's. My short times were 1.51 with these. If you are looking for a lot of traction, get some 90/10's and chuck the whole 70/30 idea to the weeds. In my opinion they aren't worth wasting money on. Like Derek said, keep an eye on your pinion angle. It can hurt just as much as help. It all depends on where you have it set.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
