A 3 Valve 4.6 Motor Coming In 2004 ?
Guest
Posts: n/a
I know, who cares about the new Avanti that is coming back but look at the last paragraph of this article. Hummm ?
Now I wonder if they mean the 2005 Mustang and not the 2004. Any of you mod motor followers hear anything ?
Here is the artcle:
Avanti presses ahead with Studebaker XUV; new sports car nears completion
Avanti Motors Corp., pressing ahead with plans to build its Studebaker Extreme Utility Vehicle (XUV) despite General Motors’ allegation that the XUV is a Hummer H2 knockoff, is also close to completing development of its next sports car.
Michael E. Kelly, CEO of the Georgia-based company, says the new model will be on a purpose-built chassis developed by Avanti to replace the outgoing model, a car based on the Pontiac Firebird/Chevrolet Camaro F-body platform that ceased production in 2001.
Kelly says the next Avanti, due on the market this fall, will carry much of the same styling as the existing models, but will be powered by the new three-valve 4.6-liter V8 Ford is building for the 2004 Mustang.
Here is the artcle:
Damn i wish i could get ahold of a set of those heads right now so that i could send those heads out 2 be ported instead of my heads.I think it would ride the fuck out.one intake valve and 2 exhaust valve,I think it would work good on a NOS car
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Will the F150 be a V8 or V6?
