Well mixed results from my 373's
I think I should of stayed with my 327's. Alot of money and no faster actually slower.
Before at BMP:
8.52@87mph 1/8mile 2.0 60 time
Last night at Sunshine:
8.55 @ 83:o 1/8 mile 1.81 60 time
Two things to note the weather was not as good,and my car was not as cool as the first time out,but on my first run I had the hood up for 45mins(blower still hot as hell).I know once you hook you usually lose a couple mph because your not spinning.................. but 4 mph??
Come on will hotter weather and a little hotter motor add up to a loss of 4mph the tires are the same height as my 18s but Ive recently changed to 373s and think that I might be going past my torque curve instead of pulling through it like I was???
I wonder if this will change when I add more boost and get a cold-air kit that frees in up some or if a lower gear is whats needed in these Roots blown cars??
Before at BMP:
What tires are you running if they are still street tires your e.t. will suffer from the higher gear.
2001 cobra
Solid axle swap 4.30's
Mac H-pipe Bullitt cat-back
Steeda uppers.
K N open Filter
12.344 at 110.24 mph
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Looks good to me...you were down 4 mph and yet you were still able to run the same ET. I would say it's more track/weather conditions than gears. MPH is a result of HP while ET is a result of TQ. The weather hurt your HP but the gears helped your TQ more. I was running 3.73 in my car and it's best in the 1/8 was 7.15 @ 98 mph so there's plenty of umph in the 3.73's, more so than in your old gears. You just need a little more ass pushing 'em is all.
Mudguts: ET Streets, and I 60' about the same as you and on the dyno I had the same or more than you so what are your 1/8 times??
DrDirt: Are saying I dont have enough ass, I think my ass is big enough and I thank you to never say I dont have enough
The loss of 4mph is what makes me think that the gear must have killed something.I even reset the computer and took out the headlight and while it felt stronger only went from a 8.62@83 to a 8.55@83 and my 60 dropped from a 1.89 to a 1.81 after but still lost 4mph.
Im wondering if maybe it will payoff in the 1/4,but usually they follow the 1/8 times.But maybe the car will pull harder up top and make the gears worthwhile?????????
Josh here is my 12.33 pass.
60---1.796
330--5.116
1/8 mile 7.888 at 88.16
You should try your car at Bradenton a see what you come up with your car might wake up on the big end. Also keep in mind my car is much lighter than yours.
60---1.796
330--5.116
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Guest
Posts: n/a
Biggest thing I see right now is comparing BMP and Sunshine. Two tracks will always show different times with or without mods..
The humid hotter air will effect a blower car more than anything else. Take it to BMP and see what you get. Like Dirt said the m.p.h. is off but the e.t. is close.
Don't forget that your 60ft. was a lot better and that will knock your e.t. down because you are slipping less and more slip usually means more m.p.h.. Just look at any Supra and that should explain that concept.
Did you change shift points at all ?
maybe the SC isnt building the same amount of boost (or as long at a high boost rate) becaust it is winding out quicker????
200 points away from a 300
Its JOEL man
I thought about the boost thing also???????
Shift points are around the same redline????????
Your car weighs less is that a FAT JOKE or what?My car looks slim too me
Ill take it BMP in a week or so and lets hope it wakes up or Im killin SAM!!!!!!!!!!:o
JOEL
JOEL
Ahhh come on Josh was close enough.
Jim
Jim
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
