New best at BMP
Old Feb 17, 2003 | 04:31 AM
MUDGUTS's Avatar
Default New best at BMP
Went Sat for T-T the weather was decent.
60---- 1.79
1/8--- 7.888 at 88.16 mph
1/4 ---12.344 at 110.24 mph
I only made two passes yesterday since my 235/60/15 bf dr are completely done they have been in use for over a year and look like wore out slicks. Next up 275/50/15 bf dr and I will replace the wimpy factory lowers with UPR adj lowers. With these two mods and nothing done to the motor other than the K-N this car should go 12.20's or possible a bit lower. Than I wil get the pullies,mass air, a real cat-back and a dyno tune. This should put me in the solid low 12's with the 4.30's gears.
Maybe it might see a 11.99 before a certain pushrod motor gets there.
2001 cobra
Solid axle swap 4.30's
Mac H-pipe Bullitt cat-back
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Old Feb 17, 2003 | 07:34 AM
Trouble's Avatar
No Soup For You
Default Re: New best at BMP
60---- 1.79
always nice to knock alittle time off the slip.
were there allot of cars running for T&T?
Old Feb 17, 2003 | 07:59 AM
MUDGUTS's Avatar
Thanks guys. Ya Scott you will get there before me. It will take some more time and bolt on's for me to see the 11's and possible a switch to the 4.56's.
The place was dead. I ran Modular Matt on the 12.3 pass. He had some motor problems seems that his NO2 bottle was full but his motor was 2-3 quarts of oil low:o . Sorry Matt I just had to bring this up.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Old Feb 18, 2003 | 05:08 AM
Modular Matt's Avatar
200 SHOT
Yeah I was gonna post about my issues sooner or later but things happen for the better i guess so whenever my car comes back out ill be a bit faster than a 12.9 on the motor .I checked the oil like 2 weekes ago and it was just fine but maybe i hurt somthing on the spray in between those 2 weeks and may have caused my oil issue.but oh well time for bad ass mods .Mudguts your car runs good for the lil sh*t that you have done 2 it and yeah you do need some new tires and rims
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Feb 18, 2003 | 05:30 AM
MUDGUTS's Avatar
You wanna sell me yours.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Old Feb 18, 2003 | 05:42 AM
200 SHOT
Sorry but no I have a slower car man i need all the advatages that i can get
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Feb 18, 2003 | 05:44 AM
vetkilr's Avatar
04 Cobra man
Im sick of you rubbing your times in my wounds
Im going to get back down there and show you how too get great times on street tires(real ones)
Old Feb 18, 2003 | 08:45 PM
vetkilr's Avatar
04 Cobra man
I was thinking the same thing.
Showoff
