Which wheels do you like?
if I had to pick...i would say the welds.
But your color car is a hard one to match...you will need that "just right" chrome wheel IMO
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
I say all those rims look ugly on that car but hey maybe thats just me
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Originally posted by "NeC"
i would think the dark grey/gunmetal colored Bullet wheels would look best...
As second choice, I would go with the 03 Cobra wheels. The machined finish matches best with the tailpipes.
The car is looking great...but not with those wheels.
I always thought the best looking wheels on the fox body are the '99/'02 painted Cobra wheels, or the new bullitt wheels. Stay away from completely polished or chromed wheels, they just don't look good with that color. Are you going with a complete 5-lug swap?
On a side note, is that a cowl hood I spy? Looks like you fixed the top too. How is it running? What else have you done to it?
