Dammit! (now turned... w00t!)
Well the quest for BFG drag radials has fallen short.... they are on national back order now and BFG has no production date set.
The Iron(FE)-Works
My daddy always said, "When you want to hammer a nail, don't do anything fancy. Just get a hammer and pound the son of a bitch."
The Iron(FE)-Works
Are these the 275/50/15's BF DR. If so they were on back order last year that's is why I had to order the 235/60/15's BF DR. These are not that bad but the bigger size is a little better. You might want to look into the size I had to go with. Where did you try to order the tires from. That sucks for me beacuse I was getting ready to order the bigger ones.
2001 cobra
Solid axle swap 4.30's
Mac H-pipe Bullitt cat-back
Steeda uppers.
K N open Filter
12.344 at 110.24 mph
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Originally posted by "Faethor"
It was for the 235/60/15...
Oh good. That means the 275/50/15 might be available you should look into them.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
OK... so bear with me for a sec... other than size... what is the difference? And how will they differ on a 7" rim?
Jim
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
Well now order those 15-8 inch rims from summitt I told you about. They are 85 bucks to your door. Then you can the 275's. :o Let me know if you need the part #.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
2001 cobra
Steeda uppers.
K N open Filter
with a 1.796 "60"
on wore BF Dr.
