fuel pumps?
Originally posted by "stangerang"
go with the high flow 255 if your are running a dry kit with small injectors......
Like Mars said, the extra volume is just going to be sent back to the tank.
Originally posted by "Road Rage"
ill prolly go 255 since its easier to change out the injectors then it is the fuel pump.
Walbro GSS307 Price $109.99
In-Tank pump 255lph @ 70psi up to 600hp
Walbro GSS340 $122.99
In-Tank pump 255lph @ 80psi up to 750hp
price depends on where ya get it.
Why? The small injectors will still flow the same rate no matter how much the pump is able to flow.
Twin Turbo '88 Mustang GT
200 points away from a 300
on a dry kit the injectors pressure gets spiked up reallt high, which takes a big pump and makes the injectors more prone to failure.....(depending on how high)
for instance, you could support 450 hp with 24# injectors at about 90 psi... but they will last for a whopping 2 months....... and possibly get stuck open....
a wet kit takes less pressure to run, so you can use a somewhat smaller pump.....
You sure about that? An in-tank fuel pump isn't too bad to change. Personally, I'd think the injectors would have more work involved to change. But I do agree with everyone else, go with the 255lph.
Matt
AIM- Wildcard302
AIM- Wildcard302
