Someone call 1-800- EXCORSIST
Old Dec 30, 2002 | 06:28 AM
Toma's Avatar
Ricer In Training
Default Someone call 1-800- EXCORSIST
So I try to start the dirty whore last night a hour after driving her and it won't start, just makes this clicking machine gun noise. I thought it was the starter so I push started the car. Car starts, runs fine but all electrical systems start going ape shit :o Gauges, CD player, dummy lights started flashing, the needles on all the gauges except the speedometer start to fly around ( Autometer tach just froze). Then I shut the car off, but dome light will not go out and starter makes same noise. The weird part is everything works with the key out of the ignition,A/C,radio,p/w,p/s
The fuses seem ok to me, don't know too much about electrical systems.
Any suggestions would be greatly appreciated.
THANX!!!
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Old Dec 30, 2002 | 07:05 AM
0HP930's Avatar
Guest
Unless your battery is toast I would recommend checking your battery terminal connections and/or the cable connections to the main bus.
Old Dec 30, 2002 | 07:57 AM
XpcorpC's Avatar
Vertically Challenged
Check Ignition Module, I had a problem like that, but only my lights were cutting on and off, I replaced my Ignition Module with a factory replacement in my mustang (which I dont have nemore), and the problem stopped... I dont know much about electrical either, all I knew was that the module was old anyways, and it wouldnt hurt to replace it. Hope this helps.
Affordable Web Design, Graphics Design, SEO, and Internet Marketing. chris@splashmediaflorida.com
Old Dec 30, 2002 | 08:38 AM
Tits McGee's Avatar
is cooler than you
Your car is experiencing Stigmata.....the second coming of christ is upon us.
Old Dec 30, 2002 | 08:49 AM
Toma's Avatar
Ricer In Training
Well that would explain the blood seeping out of the A/C vents...
Old Dec 30, 2002 | 09:09 AM
racingtheburg's Avatar
Pro 5oh
:o :o :o MY SHIT did the same thing 2 days ago i am getting it looked at tues what kinda battery u have lol recall??
Old Dec 30, 2002 | 09:11 AM
XpcorpC's Avatar
everyones car problems have been ignition/electrical related lately.... it's a revolution :o
Old Dec 30, 2002 | 08:45 PM
stangerang's Avatar
whoopdy fucking do!
sounds like something is grounding out or maybe a wire has gone bad allowing you power to stay on--- disconnet the batt so it doesnt acidentally drain ....
i'm might also be the key mechanism --- that shit happned to my sisters tempo --- it was the starting mech in the steering coulmn(where the key turns the car on) that might be the reason why everythin is still on as well.....
easy to check this stuff...... well the steering coulmn anyway --
i'd also get beneath the car and look for sparks as you try to star it --- if it is grounding out you;ll prolly see some sparks from somewhere .....
easiest way to check the soleniod is to run a cable directly from the batt to it and see if the starter turns.....
electrical problems suck --- there are so many things that can go wrong
200 points away from a 300
Old Dec 31, 2002 | 12:08 PM
Hondahunter97GT's Avatar
Red Stripe Beer!
damn my dream did that
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
