Help with Air Cleaner...
Old Dec 25, 2002 | 12:07 PM
XpcorpC's Avatar
Vertically Challenged
Default Help with Air Cleaner...
Ok, I have a 302 V8, and today I installed a 14 inch. Air Cleaner (universal) replacing my filtyhy, dented up Air Cleaner Assembly... there was a spot for the Breather Filter hose, but I tried almost everyway, and it wont even reach to the air cleaner, plus, I tried to fit it into the slots on the Air Cleaner, and it doesn't fit ANYWHERE.. there were also 2 other hoses I was told I could just cap, so I did... but what about this breather filter hose, the other side of this hose connects to the back left valve cover (looking from the front of car).. and I dunno if I can just cap this, or what.
Affordable Web Design, Graphics Design, SEO, and Internet Marketing. chris@splashmediaflorida.com
Old Dec 25, 2002 | 12:20 PM
0HP930's Avatar
Guest
Just get some breather filters for your valve covers and ditch the PCV system.
Its not like your car will have to pass an emissions check.
Old Dec 25, 2002 | 12:43 PM
XpcorpC's Avatar
I can do that? How does that work, and where can I get it done? Because the other end of the breather hose is also loose, and seems to be leaking a little bit.. and do either of the other two cords do anything? The guy at Auto Zone just told me to cap them.
Old Dec 26, 2002 | 06:14 AM
XpcorpC's Avatar
Ya, Im Lost.. my PCV Valve line, runs from the front right Valve Cover to like the upper right side of my carb., not the back, maybe I have it wrong :o I dont know, take a pic for me.. My hoses are all messed up, the dude that sold me the car must have been a complete car dumbass
Old Dec 26, 2002 | 07:44 AM
0HP930's Avatar
Guest
Originally posted by "FordMan"
Damn Porsche people need to stick with there own air cooled furry !
Leaving the PCV system on that car makes as much sense as leaving the air pump and EGR system on a car that no longer has a catalyst.
Old Dec 26, 2002 | 10:39 AM
XpcorpC's Avatar
I took it over to blue oval, they explained it to me. I need to get a Valve Cover Breather Filter, and I DID cap the rest of the hoses correctly. I get my new Shocks and Struts January 2nd, yay!
Old Dec 26, 2002 | 10:52 AM
0HP930's Avatar
Guest
With the exception of environmental concerns (such as releasing unburned hydrocarbons directly int the atmosphere) would you like to give me a good reason why you would like to run your blow by gasses back into the intake mix?
While there is an argument for ventilating the crankcase to reduce oil contaminiation, I guarantee you that XpcorpC's blowby gasses far exceed the flow that can be generated by his PCV valve. Unleaded gasoline is also less of an oil contaminant than leaded (which is one of the reasons for longer oil change periods on cars nowadays).
PCV valves also flow almost no gasses during normal cruise operation anyways, but the breather system in the air cleaner guarantees that blow by gasses will still be added to your intake mix, reducing the power that can be generated per CFM.
Thats the reason why I say ditch the PCV valves and just put some breathers on your valve covers. Perhaps FM has an argument to convince XpcorpC otherwise.
While he is at it perhaps FM can convince XpcorpC to keep his vapor canister if it goes bad.
