Need Help Please Read
While driving I blew up something and the car died. I have smoke coming out of intake, remove the oil cap and smoke and smoke from my exhaust leak on the passenger side, think its a exhaust gasket or something i dunno shit. Im gonna remove the nitrous and have it serviced I guess unless its simple...
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
Could be a gasket. Check the heads
Sorry. Isn't your car still under warranty
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Exhaust gasket?
You probably a damaged a piston and/or cylinder (or worse) if noticeable smoke is coming out of of both your crankcase and exhaust.
The smoke in the intake might be from the PCV system drawing in smoke from the crankcase.
You have carb'd or Fuel Injected engine? I might know whats wrong if your carb'd.
EDIT- nvm, you have a 97, ur fuel injected, ya, you probably blew a gasket, sorry I cant help.
Affordable Web Design, Graphics Design, SEO, and Internet Marketing. chris@splashmediaflorida.com
LOL! Solo, I hope ur car never breaks down! If so, I can see it now, he pulls it to the side of the street, pulls marshmellows out of the trunk, and makes smores
lol ok heres what i have so far, cly. 1 and 5 show signs of oil on sparkies and cly 6 has mech damage, piston owned it. Life sux guys, but the fucker is covered and i just took the nitrous kit off so they wont talk shit about o it was the nitrous bs...
2004 GT: STOCK
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
Guest
Posts: n/a
I hate to tell you but they have ways to test for the presence of nitrous.
Plus they can usually look in all of the normal hook up spots you would use with a nitrous system and tell.
But then you may get lucky like Dustin.
Should have got one of them there pushrod motors.
Best of luck getting this one by Ford. If you do pull it off, PM us and tell us which one you snowed.
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
