Holley fuel pumps....
Old Mar 14, 2012 | 01:37 PM
95coBraSVT's Avatar
banana republic
Default Holley fuel pumps....
Can they be rebuilt? Mine works...sometimes....after it's been on a while, it gets quieter (but still loud enough to hear it) and the pressure falls. Then a few seconds later, it starts up again and all is well. It has completely died once also, and I tapped it with a hammer, and it started working again.
So, can they be rebuilt and solve this issue?
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Mar 14, 2012 | 02:57 PM
blacksheep-1's Avatar
The ones we used in the mid 70s could, I guess they still can be
Holley 12-821 - Holley Electric Fuel Pump Gearotor Kits - Overview - SummitRacing.com
Old Mar 15, 2012 | 02:09 AM
95coBraSVT's Avatar
banana republic
Awesome! Thank you!!
Old Mar 15, 2012 | 08:02 AM
seifreit's Avatar
Engine Armor Coating
It could also be the motor part of the pump itself. I went through several on the race car. They would be fine for about the first 10-15 minutes then quit completely. Half hour later they would run fine again. Went through 3 this way until we finally discovered a bad ground. We couldn't have the rebuilt because the motor itself burned out. Most of the rebuild kits I have seen only replace the pump mechanical parts.
You can test the motor with an ohm meter. On the Holley Blues and Reds it should read around 10-12 ohms. If it is a lot lower than that, the motor could be bad.
Scott
Engine ArmorPerformance Coatings
http://www.enginearmorcoating.com
813-685-8333
Old Mar 15, 2012 | 02:25 PM
95coBraSVT's Avatar
banana republic
No, I can hear it spinning, but no pressure..... I will check the ohms this weekend though just to make sure.
Old Mar 15, 2012 | 04:16 PM
Zman's Avatar
I gota Cheby
if you hear it spinning but no pressure it could be the 4 little vanes in the bottom that push the fuel. A lot of times they get stuck in the round housing. Pull bottom plate off and a round piece will come out and the 4 vanes should be able to move freely. Sometimes I have used a little sand paper to clean them up.
Only 1/4 mile track I know is Gandy Bridge
Old Mar 15, 2012 | 05:35 PM
95coBraSVT's Avatar
banana republic
That's what I'm thinking Zman. The car sat for about 2 years without running. Then, one day, I decided to rebuild the carb, and replace the fuel lines, and filters, and fire it up. It fired up right away, but after driving the car for a while, it started acting up.
m4scout
Power Adders FS and WTB
Apr 20, 2011 06:28 AM
civicsi0721
For Sale/WTB Honda & Acura
Dec 2, 2008 08:42 AM
cochese
5
May 1, 2007 06:31 PM
88EFSiR1J1
Jan 23, 2002 07:56 AM
