5.0 coolant leak
Old Jan 16, 2012 | 10:19 AM
TIMMONS's Avatar
Default 5.0 coolant leak
94 5.0...i have a coolant leak but i cant seem to pin point where it is coming from...when i squeeze the upper radiator hose it seems to be coming from somewhere around the oil filter. any ideas?
Old Jan 16, 2012 | 02:52 PM
50Mustang's Avatar
sounds like the weep hole in your water pump. is it constantly leaking?
Old Jan 16, 2012 | 03:07 PM
TIMMONS's Avatar
slowly but yes...it has gotten worse over the past few weeks
Old Jan 16, 2012 | 04:28 PM
50Mustang's Avatar
i would replace the water pump it sounds like the weep hole. after time the bearing goes out in the pump and it has a hole in it to let you know that it has gone bad by leaking water not alot but enough to notice. it is showing underneath the pump right?
Old Jan 16, 2012 | 06:56 PM
TIMMONS's Avatar
ya right at that area. so whats replacing the pump involve? done a few on different cars but never a 5.0
Old Jan 17, 2012 | 11:05 AM
50Mustang's Avatar
never did it on a 95 did a couple on my fox's. if its pretty much the same motor all you do it take the belt off and the fan and the fan shrould and you can get to it pretty easily.
Old Jan 17, 2012 | 03:42 PM
TIMMONS's Avatar
well thanks for the info. just picked the car up about a month ago after wrecking my cobra. car has 198k on it and cosmeticly is very nice but i could tell the previous owner was not that mechanically inclined because there has been a few minor problems that he didnt or couldnt fix that was something simple as a loose wire. work in progress is all i can say.
Old Jan 17, 2012 | 04:55 PM
50Mustang's Avatar
no problem man anything i can do to help
Old Jan 22, 2012 | 06:46 AM
50Mustang's Avatar
be sure to put the belt on the right way. if you reverse it your car will over heat.
fordboy305
Jan 29, 2011 06:22 PM
nismo180
Oct 15, 2005 03:55 PM
Drewpw4ng
Sep 24, 2004 04:02 AM
bouncer
Mazda Tech
Aug 18, 2003 01:38 AM
