Cooler Intake Air
I have a 99 mustang with a Kenne Bell blower on it. It is the 6 psi version because I din't feel like loading up the entire front of the car with extra crap (weight) since I autocross it. Would it be worth drawing through some type of heat exchanger into the blower? Or would this be a waste of time?
**Weight on the nose of Mustangs is like the kiss of death, i'm currently competing in the over 3 ltr class and run very competitively with the v8 mustangs, even though my (full time) auto cross car is a v6. This is because you get 2 cylinders less weight, aluminum heads and tube headers, all of which save weight.
It would be good to know your IAT2 temps before you start making any changes. Once you have that baseline you can decide if you need to cool things off. If your tune is pulling timing at the IAT2 temps you record, then you may want to invest in additional intake cooling. Front end weight.. tell me about it.
I don't recall what they are but Brian was telling me they were very hot, makes sense since there is no method of cooling it. I don't really want to blow alcohol through the blower as with a meth injection kit, so I was looking for some kind of alternative.
Thats the problem using a roots blower
Meth will not cool it down unless its sprayed "after" the blower.
Your best bet is making a cold air kit. Or getting an IC that goes after the blower.
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Its a $$$ money. The more sophisticated the cooler.. the more money it is. This is why turbo and centri's rule as front mount IC's can be used to kill the heat in the charge temp.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Jake1234588
For Sale/WTB Honda & Acura
5
May 4, 2011 10:06 AM
BABILLARACING
May 20, 2006 05:15 AM
