2001 Cobra Tach
Old Nov 27, 2002 | 10:29 PM
TotalChaos's Avatar
Adapt and overcome
Default 2001 Cobra Tach
Hey Guys, I have a '01 Cobra, 5 spd... need to know how to hook up an autometer tach... i have the tach adapter but cannot figure out what to hook to in the '01. Any help would be great. Thanx..Nick
"If your teeth get knocked out... swallow them and get back in the fight!"
--I'd rather be tried by 12 then carried by 6--
Old Nov 28, 2002 | 01:54 PM
TotalChaos's Avatar
Adapt and overcome
Can no one help a fellow ford driver out...lol
Old Nov 28, 2002 | 05:13 PM
Sam@Coastal's Avatar
Does not race from a roll
not sure which adapter u have, if u can explain what they are telling u a little more i'm sure i can help u out, i've encountered 3 or 4 different adaptors, all of them being slightly different
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
Old Nov 28, 2002 | 08:54 PM
TotalChaos's Avatar
Adapt and overcome
Alright great... I forget the part number, but i think thats it's the only one that autometer sells. It's just called a "tach adapter". i dont know if thats all you need or what though. thanx again
Old Nov 29, 2002 | 08:07 AM
I'm pretty sure thats the one that requires you to cut the main feed for the coil packs and split it in order to run it through the tach adaptor, i can't remember the color but you can catch it near the passengers side firewall running into the main harness, there will only be two wires per each pack, so check and see which one is concurrent to all packs and then look for that one in the main harness, like i said u have to cut it and run the one side through the tach adaptor then reconnect it out the other side. anyways hope this helps.
www.coastaldyno.com
Old Nov 29, 2002 | 02:13 PM
TotalChaos's Avatar
Adapt and overcome
thanks alot i will try that and see if it helps
