More Info. On the New 5.0 "Cammer" Crate Motor
Guest
Posts: n/a
Some of this is a repeat but there is some additional info. in the article.
FORD RACING’S NEW 5.0-LITER ‘CAMMER’ REVOLUTIONIZES CRATE ENGINES
LAS VEGAS, Nov. 5, 2002 - Ford Racing Technology will revolutionize the crate-engine concept when its new 5.0-liter Cammer crate engine becomes available in 2003. Instead of modifying a standard production engine to suit non-stock applications, Ford Racing specifically designed the Cammer to be one of the most technologically advanced crate engines any manufacturer has ever offered.
This high-performance retrofit is an all-aluminum, overhead-cam, 4-valve engine that is a perfect repowering upgrade for vintage Mustangs, street rods, and classic truck projects.
According to Ford Racing Technology engine engineer Andy Schwartz, “The 5.0-liter Cammer delivers a healthy 425-430 horsepower at 6700 rpm. The torque curve peaks with 370 foot-pounds at 4000 rpm.”
The 5.0-liter Cammer crate engine is based on the SVT Mustang Cobra’s 4.6-liter 4-valve V-8. However, the crate version has several unique qualities and components, including:
Larger cylinders (94mm vs. 90.2mm) for 5.0 liters of piston displacement
Flanged cylinder liners
Reinforced crankcase web areas
Forged pistons
11.0:1 compression ratio
Ported heads
Higher-lift cams (12mm vs. 10mm)
Beehive-shaped valve springs to accommodate the higher lift
Modified roller-finger followers
Multi-layer steel-insert head gaskets
Higher-flow fuel injectors
3-piece cast-magnesium variable geometry intake manifold
Higher-flow, dual-cone-spray fuel injectors
The 5.0-liter Cammer crate engine will be shipped with a stock Mustang Cobra oil pan and exhaust manifolds. Installation will be eased substantially by a choice of six different 4.6-liter 4-valve modular wiring harnesses being created specifically for the 5.0-liter Cammer crate engine.
“We intend to grow the interest in overhead-cam technology,” said Dan Davis, director, Ford Racing Technology. “This is the future for tuners, project-vehicle builders and aftermarket car and truck enthusiasts. There’s no reason why a crate engine can’t start and perform as well in an aftermarket setting as the engines in production automobiles and trucks do. The 5.0-liter Cammer crate engine will provide top performance, a slick underhood appearance and excellent driveability without the hassles attached to carburetors and distributors.”
The under-carriage of Ford's FR100 features the 5.0-liter Cammer engine that produces 425-430 horsepower.
Forged pistons
Ported heads
Sounds good but what's the pricetag?
Is it like the GM performance Ramjets that come with a computer and harness etc. complete?
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
I think I wanna save for one of these after I get some drivetrain problems worked out.
Especially for 425-430, hp n/a!!!!! damn I need a towel!!!!
85' Mustang GT 5.0 $1500 obo!!!
03 FOCUS ZX3
NICK
03 FOCUS ZX3
NICK
