Question about springs
Right now i have FMS 1" springs all the way around and itsa really stiff
im running lakewood 70/30's in the front and 50/50's in the back!
i was thinking about puttin 4 banger springs in the rear (b/c i hear its better for the launch) and i wanna know , how much will it raise the read end of the car up. i like the looks of my car right now and i dont want itto look like a 69 camaro
and if not the 4 cyl, which setup should i go with??
thanks
Donnie
and if not the 4 cyl, which setup should i go with??thanks
Donnie
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
ok thanks
also what setup would someon recomend for a good launch spring and still keeps a nice decent low profile
Guest
Posts: n/a
I'm not even sure that the rear springs are different between the 4 and 8 cars. If you go to NAPA, look in their spring book, it lists in great detail what different part numbers there are for all the different options. I did this alot when I worked there and put 4 cyl springs on my car, but I kept my stock v8 rears.
Originally posted by "Exhaust Etc"
ok thanks
ok thanks
you can soften it up at the track and lower it back down for the street
200 points away from a 300
what about the eibach spring w/air bag setup???
well i can deal with a stock or almost stock height but i dont want to raise it up past stock, the hatches just dont look good that way
i like dustins idea with the coilovers, ill have to look into it
Guest
Posts: n/a
Originally posted by "mustang23"
That will work the best as far as drag racing, but its probably designed for stock ride height. You really don't want to drag race a lowered car anyway, cause its not really gonna work.
Dave is on the money here. You will have to sacrifice the lowered look if you want to have a good launching car. You can do what I did and get taller tires to eliminate some of the wheel well gap.
