Question about valve covers
hey guys/gals, I've been out of the loop awhile, I hope everyone is well.
I am finally starting to get to adding my Trick Flow parts to the Mustang (4 years in the making, lol). My question is with Trick Flow Twisted Wedge heads, can I use the stock valve covers? I still need to get some rocker arms, so, I am hoping I can just use the stock valve covers.
I blew out the water pump in February, so the car has been sitting since then. Since I have it torn apart, I am going to go ahead and add the TFS stage 1 cam, the TFS TW heads, but I still need to get a set of roller rockers.
Thanks in advance.
Thanks in advance.
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
John
Stock valve covers should work but you will probably need to machine the baffle out completely. That is what I had to do to clear the roller rockers on my car. Also look for 91-93 covers. They don't have the cast ribs on the inside that can get in the way depending on the rocker arm.
Scott
Engine ArmorPerformance Coatings
http://www.enginearmorcoating.com
813-685-8333
Scott
813-685-8333
cool, thanks for the responses!
John
John
