Looking for aluminum thermostat housing 5.0
Old Jun 7, 2011 | 02:05 PM
Razor's Avatar
Default Looking for aluminum thermostat housing 5.0
Need to buy an aluminum water neck.. So I can delete the bypass port on it. 5.0 motor.
Dont want to spend 100 for a billet piece.. does anyone make an in-expensive thermostat housing?
Are factory aluminum ones still available?
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
Old Jun 7, 2011 | 02:56 PM
StangItMan's Avatar
Yep water outlet #84884, from Advance ... less the ten bucks!
The '87 Coupe to be built and raced in our son's memory.
Cameron Lee Koss - 9.1.1991 - 8.05.2011
I can do great things when not experiencing "Man-A-Pause" StangItMan '08
Old Jun 7, 2011 | 03:21 PM
1BADP71's Avatar
E & I Certified
nice save !
Old Jun 7, 2011 | 07:21 PM
Tiffiny's Avatar
I can fix your bullshit
ford motorsport has a chrome one for like 30 buxs ill look to see if i have one its yours..
Old Jun 9, 2011 | 06:17 PM
Razor's Avatar
John,
I wanted it to be aluminum so I could shut down the bypass hole.
I'm scared of chrome or polished.. anything slippery couuld be a disaster if the upper hose pops off.
I'll call you tomorrow on sumthen else
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
Old Jun 11, 2011 | 03:17 PM
Razor's Avatar
Heres a before and after
The aluminum housing comes with a pressed in fitting with loctite. I uses a propane torch to heat it up and vice grips to pull it out.
Then..
I had the guys at Amazon Hose in Tampa tap out the hole to 1/2 NPT for a few bucks and I installed the 1/2 NPT hex plug. Pretty snazzy and cheap.
Total cost less than 20.00
edit.. look how the rubber cap starts cracking.. imagine if that thing lets go and coolant hits the track when you hauling... big time bad newzzz. Now you know why I made the change.. I also installed a 160 stat and drilled a couple 1/8 inch holes into it.
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
G35FTMFW
For Sale/WTB Nissan
Oct 17, 2009 10:31 AM
grn93sleeper
For Sale/WTB Nissan
4
Jan 27, 2007 05:41 PM
teal_Deal
4
Dec 9, 2006 09:18 AM
tony122
Nov 26, 2005 06:24 AM
jeffronismo
Nissan/Infiniti Tech
Jan 11, 2004 09:26 AM
