another pos problem. please help
so i just got the motor running and then car started to vibrate/shake violently.
so i checked balancer, checked u joints, replaced tie rods, replaced motor mounts, replaced tranny mounts, and checked bolts on drive shaft and it still shakes horribly
if im cruising anywhere from 0-50mph it doesnt shake, but if it doesnt u cant notice it. it only does it when your above 55mph
so when i was comin home last night i got it up to 65mph put it in neutral and reved it up some but the vibration stayed constant, didnt go up with rpms or down with rpms. also when im sittin still it doesnt vibrate
another problem, i dont know if its related, is my clutch is very tight and hard to put into gear.
when i checked the u joints the drive shaft doesnt have play with the u joints BUT IT DOES have a little play in the tranny and rearend
if u have ANY IDEAS please call or post on here
813 482 1561 Wes
813 482 1561 Wes
Bent driveshaft or it loss it's balancing weighs
Meaning it sounds like the driveshaft needs rebalancing
Pyramid in St Pete can do it
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
NEW Machine
89 Mustang GT
True-Street trim
www.alkycontrol.com
thats wat a guy at advance said but then he looked at them and said
"DAMN, u need need tires! but their not separated" lol
we looked at it and let him drive it. he was sayin that HE noticed it runs ruff and i just might be use to it and then once it gets to higher speeds its worse and the alignment problem comes in.
so he thinks the balancer might have been the wrong one or it might have shifted
yea thats wat another guy i ran into said
i use the sticky weights instead of the clip on ones. but is it possible a weight came off and could be doin this?
i put a brand new, fresh from advance, balancer in anyway.
ok
well i know i need better tires but want to fix it before i get stuff like that. im just so sick of dumping more money in this pit. hasnt run decent in over a year
tires out of balance maybe not as bad of a vibration, but a bad tire will vibrate like the car is coming apart.. Its def in your tires/rims. You said it yourself,
put it in neutral and reved it up some but the vibration stayed constant, didnt go up with rpms or down with rpms. also when im sittin still it doesnt vibrate. if it was motor related if would vibrate with rpms moving up or down. Tires and wheels are easy. Do what Dr Dirt rec. swap wheels with somebody and see. You could be chasing this all day with all the variables
Only 1/4 mile track I know is Gandy Bridge
