HELP My car sounds like a boat!
Today me and a friend installed a Mac o/r Hpipe on my car. I must say it is one of the hardest things I have everdone mechanicly. Anyway on to the problem: When I got the Mac hpipe on, everything lined up fine with a little force. the header bolts is where the problem is, especially on the passenger side where I couldn't even get the bottom one all the way down. Now it sounds like I am running open headers. What place is open on Sunday that can tighten them for me. I am guessing it will only cost a few bucks?
Thanks
Thanks
Black 1999 Mustang GT 5spd
A few bolt-ons...
13.982@100.44mph Stock
A few bolt-ons...
Best thing to do is to keep both halves separated. Line up each side to where it makes a seal with the header, then clamp the H-pipe portion together. I'm not sure how the header flanges are on the modular motors, but I think one side may need some high-temp RTV gasket maker.
Do both header collectors look like this:
If so, you just need to mess around with it until you can get both bolts tightened. If one side is NOT like the collector pictured above, you will need a gasket as I mentioned before.
Its not that I couldn't get them tight enough, its just that I could never get a good enough angle to get the the nut all the way down. Is Rainbow Muffler open on Sundays?
A few bolt-ons...
A few bolt-ons...
Try different combonations of extensions and those flex joints. You'd be amazed at what can get you to a bolt. Or get a mechanically skilled friend to take a look at it and see if he/she can get a better angle on the bolt. Sometimes another head can see a route or angle that you missed to get to that bolt.
I thought since the I took the cats off then they have no responsibility towards it? I'll try again but I really want to get it fixed today. Can anyone on this board help me out today?
A few bolt-ons...
A few bolt-ons...
