Burnouts !
Old Oct 2, 2002 | 09:24 AM
Strokd85's Avatar
Daddy-O
i roll into the box, 1 quick rev to turn the tires, roll out a full car length (you'd be surprised how much water you push). then it's a pump of the brakes and up to 7k in first click 2nd and around 6500 until i get a decent puff of smoke. Roll forward, cut a 1.355 60' and be happy...
also, depending on the water box and how large it is, if there is enough water i'll just roll through as it covers the entire slick without slinging water up into the wheel well...
good luck man!
Old Oct 2, 2002 | 11:52 AM
4.6Power's Avatar
The H N I C
The hell with line-lock, good old heel toe works for me.
Does that look normal to you?
Old Oct 2, 2002 | 12:05 PM
bitemark46's Avatar
Got traction?
Scott, the times I've seen your burnout you don't spin the tire enough in the water box IMO. 2nd gear I agree with and dump it at 4k+ then mash on the brake. U still need to come out harder! Say about 6k. I'm sure u can cut 1.5's. I might be on slicks on the track day the 27th, you mine biotch! -Mark
98' cobra
Old Oct 2, 2002 | 12:19 PM
racingtheburg's Avatar
Pro 5oh
I like 360's better but my car gets loose all the time for a burnout i need slicks but i have a bad axle(sp) it tends to leave a lil darker mark on the right side so I dont know if i should get them hmmm newayz I have tried to do burnouts with radials but it doesnt do ne thing.I have tire spin all the way past where bmp's first box in the middle of the track soo i have to get slick's . well here is a pic of my friends stang doin a nice burnout in front of my house
PS.wiring problems are making it hard for me to go to track day does ne on know how to wire a fukin car!!!!!!
Old Oct 2, 2002 | 04:10 PM
Hondahunter97GT's Avatar
Red Stripe Beer!
lol power braking owns me, but i got new sticky tires and wanna spray off the line now
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
Old Oct 2, 2002 | 04:44 PM
miami97cobra's Avatar
by floorin it and pressing the brake is how i did burnouts in my last 5.0> but my 97 cobra has 4 wheel disc brakes so could i do it in the same manner >>>>>or what do i need i heard of a thingamagigy called >>lock up?>?> which enables only the front brakes to .....brake...what du i du ?>??>
Old Oct 2, 2002 | 06:21 PM
4.6Power's Avatar
The H N I C
that is the same thing as line-lock. Paul's Performance makes it for ABS cars, but he wants like 300 for it when I line lock kit is a little over 100.
Also, you can still launch it hard and hit your brakes, it will work.
