Header clearance problems...Any ideas?
Just put on LT's and the right side is hitting the unibody. The headers are jet coated and I was wondering if I can heat up the header that's hitting and bend it alittle. My concern is that since it's coated I might take the finish off. Anyone have any ideas? And to think I said I'll never do header install on a modular car again.
That was a crock. -Mark
98' cobra
98' cobra
it's called a hammer!!!!
lontubes just dont mix well with our cars....
you can prolly bend it, but i'm gussing you will trash the coating..but i'm not sure.. call the manufacturer and ask them how much heat the coat can withstand...
you'll prolly need to get them over a thousand degrees to bend the way you want
200 points away from a 300
There actually a decent quality header for the modulars. There Jomars old BBK's. The coating is good. I think if I get the header to glow I might be able to bend it slighty. -Mark
98' cobra
98' cobra
98' cobra
98' cobra
Originally posted by "FordMan"
After driving mine a few times they almost moved into place themselves. But to finish them off I got a block of wood and pry bar and bent them away from the frame when they were hot, now they fit fine.
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
