really need help with my 5.slow
Old Mar 9, 2011 | 11:21 AM
GNs-r-slow's Avatar
Bondsman
10 degrees is factory setting. Thats 1st on the old skool mod list besides dumping the factory air box is to bump the timing
Old Mar 9, 2011 | 12:12 PM
Superwes98's Avatar
i understand that the 10 degrees is stock, thats why i put it back to 10 degrees. so that eliminates a possible problem
the cap, rotor and cap CUP r new as well.
and the new wires and plugs look new. dont know how else to put it
also at wot it doesnt have as much power as before but it clears up and doesnt surge or anything like that
Old Mar 9, 2011 | 12:35 PM
GNs-r-slow's Avatar
Bondsman
When you start adding parts, you will no longer run STOCK timing!!! More air, more fuel, REQUIRES more timing. READ YOUR PLUGS!!
Old Mar 9, 2011 | 01:07 PM
Superwes98's Avatar
i had it set at 14 degrees before and put it to 10 degrees trying to eliminate problems
Old Mar 9, 2011 | 03:09 PM
GNs-r-slow's Avatar
Bondsman
what do the plugs say? Also on the TPS voltage did you check the WOT voltage also?
Also did you clear the codes after changing / resetting the sensors?
Old Mar 9, 2011 | 03:30 PM
Superwes98's Avatar
well see heres the thing, my scanner will work on my friends 92 ranger and another friends 87 GT but wont do anything on my car. so i dont know wat codes r bein throwin if theres any
and the old plugs read normal
Old Mar 9, 2011 | 04:19 PM
  #17 (permalink)
GNs-r-slow's Avatar
Bondsman
Did you clear them? Being you cant see if there are any, dont need a scanner for that
Old Mar 9, 2011 | 04:22 PM
  #18 (permalink)
Superwes98's Avatar
reset it: as in disconnect battery for 30+ minutes? yes i did
Old Mar 10, 2011 | 05:13 AM
  #19 (permalink)
Superwes98's Avatar
could it be O2's? iv changed them out but with others i THINK work.
BOX SENTRA
Oct 12, 2006 08:26 PM
