Looks Like Sean Hyland Is On The Crack Pipe Again !
Guest
Posts: n/a
(Hopefully Sam does not get pissed at me for posting this. )
Sean Hyland Cobra S4[/siz]
The questions are arising, what is the new Sean Hyland Cobra S4 Lightweight?
The key elements of the Sean Hyland package for the 2003 Cobra are a 250lb weight reduction via various vehicle components. Some of the key new components SHM is introducing is the Carbon Fiber hood and trunk lid, titanium exhaust, and tire pressure monitoring system (replacing the spare tire, jacking equipment, etc., similar system to that of the Corvette).
Engine power is increased to 500BHP via a carbon fiber cold air induction system, increase in the supercharger boost, and exhaust system. Suspension is improved with adjustable shocks, springs and bushings. The differential is replaced with a heavy duty unit.
Expected MSRP for the new 2003 Cobra S4 is about $60,000 :o . Below is a breakdown of the modifications that are performed.
Check back at a later date for the new 2003 Sean Hyland Vehicle line-up...
Lightweight Package
Carbon Fiber Hood
Carbon Fiber Trunk Lid
Lightweight Floor pan Sound Deadener
Lightweight Battery
Lightweight Front Brake Rotors with Aluminum Rotor Hats
Titanium Exhaust System
Tire Pressure Monitoring System (Spare Tire Delete)
Engine Package
500HP Engine Package
Carbon Fiber Cold Air Induction
Titanium High Flow Exhaust
Revised Supercharger Drive
Suspension Package
Adjustable Shocks
Specific Rate Springs
Revised suspension bushings
Tubular Front Sway Bar
Adjustable Caster/Camber Plates
Chassis stiffening kit
HD Limited Slip Differential
Wheel and Tire Package
Magnesium 5 spoke wheels 18x9 front, 18x10 rear
265/35/18 BF Goodrich G Force KD front tires
295/35/18 BF Goodrich G Force KD rear tires
Interior
Billet 6 speed shifter
Serial number plate
Embroidered Headrests
Options
Recaro Leather Front Seats
Brembo Front Brake Kit
Lightweight Package
Carbon Fiber Hood
Lightweight Battery
Engine Package
Suspension Package
Adjustable Shocks
Interior
Serial number plate
Options
500hp? That is a Lightning pulley, headers, chip and full exhaust. Total cost for the (sound the heavenly bells) 500 hp, 2k. And Hyland probably means crank hp while I am talking about rwhp. What a crock. Sure, it sounds cool, but it is not almost 30,000 dollars worth of extra cool. Maybe we'll luck out and the 60k pricetag will be in Canadian dollars.
But, if Hyland went past the cam covers in that car............me no touch with 10 foot pole, I'd run from it if someone gave it to me. Even if it were free, it wouldn't be worth all the headaches it would cause. I know this first hand.
