Suspension help
Old Jan 29, 2011 | 07:52 AM
1badd7's Avatar
Default Suspension help
I have a 2004 lincoln Navigator with about 85,000 miles. As you may guess one of my air bags seems to be leaking. I haven't checked it to make sure but as I call around everyone tells me not to fix it but to convert it to springs. It seems to be about $600.00 for the standard kit and about $1,000.00 for a kit that Arnott had that drops it about 2".
Does anyone know of any other kits that would lower my Navi' without such a big price jump? Should I try to fix or replace the air bag that's leaking? Let me know if you've had any experience with this issue.
I'm not an alchoholic I'm a social drinker, I just happen to be very social
Old Jan 29, 2011 | 08:56 AM
GNs-r-slow's Avatar
Bondsman
If its only one air bag, I'd check into price to replace the one and compare to conversion. Those lines have a tendency to leak also. I'd look into it before you make a $600-1000 comittment
Old Jan 29, 2011 | 05:40 PM
herrcomestrouble's Avatar
I agree, more than likely its a line. They sell union/splice kits to fix them for fairly cheap. And the airbags are not that expensive. The only thing really expensive is the air compressor itself. Get some soap/water in a squirt bottle and start spraying on the lines/fittings/air bags until you see bubbles... then decide from there.
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Jan 29, 2011 | 06:21 PM
1BADP71's Avatar
E & I Certified
This ^^
Old Jan 31, 2011 | 08:11 AM
NT_Hardcore's Avatar
bassheadsent.net
i had this problem with an eddie bauer expo, replacing the bag (if it is the issue) isnt hard. we found replacement bags real cheap on line. there is a sensor you can move and/or flip which will change how much pressure the bag will be filled with. we flipped it on the expo for a few inches of drop.
http://www.bassheadsent.net/
Old Jan 31, 2011 | 08:24 AM
1badd7's Avatar
Thanks for the help guys. Do you know of any shops I can take it to in Fort Myers? I only have one day off a week so it's pretty tough for me to do it myself. It also seems everyone I call doesn't wanna mess with it at all.
