Fox wiring harness
Old Jan 6, 2011 | 09:34 PM
  #21 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by $hawn
that dash isn't a plug and play by any means lol. Im pretty sure it will plug in to the main body harness and will all pin the same from the dash back except for the factory f/p. You're not using the PCM. just check that it does plug in to your headlight harness
what I got with the harness. Dash wiring, everything that goes to the fuse box, through the firewall, and everything that comes through the drivers side grommet that wraps around the front of the car under the hood. Everything but the PCM wiring that comes from the passenger side.
Old Jan 6, 2011 | 09:43 PM
  #22 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by Tiffiny
You can use any of the harnesses...as long as you have the whole harness
I have a 93 4 cyl complete harness from front to back
89 tilt column and a 92 dash ..with a little modifying on the platic column cover around the column it can be done if you want to...
as far as the harnesses some of the connectors like to the wiper motor and the wiper switch and getting the rite cluster is were most of your problems will be, but if you get all the same stuff from the same car you will be fine
and the gauges there are a couple of different ways to make them all work .
simpilist way would be to run wires from you cluster to your senders like water and oil,tach very simple to figure out...
you can tap into the ignition switch to make all of the other stuff work
like fuel pump ,msd,ect
or if its not a street car it can be done even easier make your own harness...
if you look you can find an aftermarket harness not painless from 80 to 300 bux
but although not that hard, but time consuming splicing everything together and then you still need some of the stockharness for the end plugs to the connections. pita if you ask me
Dont need no wipers, no stock gauges, fuel pump ect. Only looking for keyed IGN, and lights, starter and charging.....everything else is useless. I'l have to drag it out and plug some stuff in.
So in need to check the column plug and headlights?
Old Jan 6, 2011 | 09:45 PM
  #23 (permalink)
GNs-r-slow's Avatar
Bondsman
I see none of those harnesses are relayed and then I would need a switch panel.
Old Jan 6, 2011 | 10:01 PM
  #24 (permalink)
GNs-r-slow's Avatar
Bondsman
Headlight harness is included in the harness I got. I'll lay it out and post up some pics.
Thanks for you the help
Old Jan 7, 2011 | 03:04 AM
  #25 (permalink)
$hawn's Avatar
lives in a glass house
the only actual plug on the column is the ignition switch and i believe they are the same untill 94
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jan 7, 2011 | 03:14 AM
  #26 (permalink)
GNs-r-slow's Avatar
Bondsman
How about the signal stuff? Bottlefed posted he had to switch some stuff over from the later colum to work on the 89 column
Old Jan 7, 2011 | 03:25 AM
  #27 (permalink)
$hawn's Avatar
just use the a 90 up mulitfunction switch. end of problems...
Old Jan 7, 2011 | 04:23 AM
  #28 (permalink)
bottlefed93's Avatar
^^^ what he said.
Every time I cross one thing off of my TO DO list,I add two more!!!
Old Jan 7, 2011 | 05:42 AM
  #29 (permalink)
Tiffiny's Avatar
I can fix your bullshit
no but there are 3 circuits that you can add a relay .relays are cheap and easy to wire.
Old Jan 7, 2011 | 10:50 AM
  #30 (permalink)
GNs-r-slow's Avatar
Bondsman
Man you guys are tough to get answers from!! Thanks for everyones help
