question!!
Old Dec 25, 2010 | 06:13 PM
fordboy305's Avatar
BuLLiTT
Thumbs down question!!
So I traded the crown vic I had for a 96 ranger splash, v6 3.0l 5speed.
So far I installed a 17" electric cooling fan and nothing else
But I was wondering if I could get a v6 mustang transmission and swap it.
Would it fit on this motor???
Only reason I was thinking of doing that is because the transmission on it now sucks, I hav to floor it so 2nd gear can go in or wait til it revs down lik 20 seconds so it can allow me to shift to it, but not only that it is slow as f×ck. I ran a 0-60 in 11 seconds. And I know its not a big v8 but the motor I know can do more. So any ideas please let me know.
Thanks
Old Dec 26, 2010 | 11:32 AM
blacksheep-1's Avatar
So you're saying the current trans is broke, yes?
IMO check the current gearing on your vehicle, then check the ones on the mustang, you can potentially screw yourself over if you get a trans with either too high, or too low of a first gear. No one likes to drive 3 feet and have to shift. My wife has a v6 ranger step side, and it's actually pretty decent with an auto, so the 5 speed should be even better.
Old Dec 26, 2010 | 12:02 PM
fordboy305's Avatar
BuLLiTT
well thats the thing, i drive lik 5 feet and shift to 2nd, but my 2nd gear only goes in easy when i rev my 1st to over 3000rshared_pm or i have to wait till the motor revs down so it goes in.
Its lik if the tranny is low on fluid but its not, so i just figured if i can get a used mustang tranny for 300 bucks i can junk this old one and that way i dont shift every 5 feet. But i just need to know if the 3.8l v6 mustang tranny fits my 3.0l without adapting anything.
Old Dec 27, 2010 | 11:50 AM
barry bledsoe's Avatar
The lost pony
clutch master or slave could be bad or have air in it
Old Dec 28, 2010 | 01:52 PM
fordboy305's Avatar
BuLLiTT
Ok so I gt another problem... every time it starts it takes 10 to 15 seconds to start, when it starts up for a bit and put it in 1st gear and start moving I accelerate and it stalls then it keeps going normal
At first I thought it was my fuel pump failing to send fuel but today it stalled and turned off on me and I kept crankin it 4 like 35 minutes and when it started it started missing and sounded lik crap. It ran weak till it turned off on me again and then another 10 minuts till it started again then it ran normal. Plus when I come to a stop or turn it smells lik strong fuel from the rear but no leaks
Anyone have any idea what this could be???
Old Dec 29, 2010 | 05:47 AM
The lost pony
does the ck engine light come on . pull codes. could be a bad sensor or connecter. or stuck injector. sounds like its flooding if you smell fuel. pull the dipstick and see if the oil smells like fuel.
Old Dec 29, 2010 | 06:17 AM
Graves's Avatar
I think you can swap in a T5 tranny if you use a turbo coupe belle housing. Just can't remember if that is just for the 4 cyl though.
Old Dec 29, 2010 | 07:07 AM
fordboy305's Avatar
BuLLiTT
ok today im gunna check out the motor and then run an obd test because if the check engine light is on probably the bulb went out like most of em but ill come back if anything tonight
Old Dec 29, 2010 | 04:22 PM
fordboy305's Avatar
BuLLiTT
No it doesnt, but wouldnt that be if i had bad piston rings??
i ran a compression test it came out 151psi per cylinder
Old Jan 4, 2011 | 04:34 AM
fordboy305's Avatar
BuLLiTT
ok so this motor has too many problems already. im deciding on doin a v8 swap maybe a 5.0, ithink it would be best doing that and keep my mind busy.
so thank you for your help huys
