A few questions??
Old Sep 5, 2002 | 04:57 PM
Modular Matt's Avatar
200 SHOT
Default A few questions??
ok i was thinking of getting a drive shaft soon and was wondering wich 1 i should get? i was thinking a carbon fiber drive shaft but i duuno were 2 get 1 and if it is worth the extra $$ and were can i order some denso plugs.Were could i get some falken azenies 245/50/17's ? i need them becouse bald michallens dont cut it while turning but bald nittos still do good.
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Sep 5, 2002 | 05:04 PM
bitemark46's Avatar
Got traction?
Mateo, a carbon driveshaft or alum driveshaft would work the same with simuliar results. A carbon will twist alittle if your on slicks thus giving a rubber band affect. But I don't think you'll see a diff in ET. Save your money get a alum one. As far as tires check out www.tirerack.com They have some pretty cheap prices. -Mark
98' cobra
Old Sep 5, 2002 | 06:04 PM
Bullitt 3309's Avatar
Got Mod Motor?
You can pick up the Ford racing Aluminum Driveshaft for around $160.00
Member Modern Mustangs of North America
http://www.modernmustangs-na.com
Old Sep 5, 2002 | 07:22 PM
Tits McGee's Avatar
is cooler than you
www.discounttiredirect.com is better. free shipping. no tax. $123 apiece in your size.
Old Sep 5, 2002 | 11:12 PM
4.6Power's Avatar
The H N I C
PST for a drive shaft.....I will give a better responce tomorrwo I am kinda drunk right now
Does that look normal to you?
