351c turbo questions?
So I have a 351c that's .60 over and has ported 4bbl heads with aftermarket springs, and valves in it, a eagle forged crank, h beam rods, and forged pistons in it. I have a 87 coupe I'm putting it in and wanna turbo it. So this is my question, what size turbo and what gear should I run in the rear, single, or dual, and what size cam would work the best. Any help is appreciated, thank you!
You'll find with a turbo, that the gear will be something to play with, we had 3.27 but wished i went with a 3.08. Let the gear lug the engine down to keep it in boost longer and see what traction problems you'll have.
As far as turbo, like said above, 75mm or bigger and i would go with a t6 style flange. With a 351, backpressure will become a problem. We had a t4 on a 363ci and the t6 would've been better and cheaper. Look it to the s400 (75mm) or a s480 (80mm), great turbo for the $$
john
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
You've been working on your car long enough to know that's funny now.
john
john
yea i agree i have been workong on it for a while.but only because im to anal about stuff.also i dont want to build the 95 GT i got my buddys 94 cobra and had alot of parts on it that i was going to buy at some point.i think you know him you were on his website awhile back
