How should I fix this???
Old Dec 12, 2010 | 02:34 PM
mustangman101's Avatar
89 2.3 91 SSP 5.0
Default How should I fix this???
There's a bolt hole on the bottom Passenger side fender extension that is in a fiberglass piece of the fender extension. well I was taking the nose of the car off to paint the metal behind it, to discover that the hole was cracked all the way around it from the previous owner or something. Now, the hole is much bigger and I'm not really sure how I should go about fixing it. so that i can bolt it down and be tight and secure.
Attachment 143432
Was thinking of using fiberglass and resin to basically patch the hole, then repeat the process a few times sanding in between until the same thickness as original then drill a hole in it...
Any Ideas???
Will take a pic a few mins so you can see what im talking about....
Thanks
Old Dec 12, 2010 | 02:49 PM
purple87lx's Avatar
just a single cam hatch
Where are you located?
Old Dec 12, 2010 | 02:54 PM
89 2.3 91 SSP 5.0
palm coast
Old Dec 12, 2010 | 03:35 PM
89 2.3 91 SSP 5.0
if you have any ideas, please let me know. I cant put the nose of the car back on until i fix this
Thanks
Old Dec 12, 2010 | 03:49 PM
SVT1996Cobra's Avatar
What?
invalid link for me, but can you just use a washer slightly larger than the hole?
Old Dec 12, 2010 | 03:50 PM
89 2.3 91 SSP 5.0
Originally Posted by SVT1996Cobra
invalid link for me, but can use just use a washer slightly larger than the hole?
im not sure that it would hold properly.
Please let me know if you have any ideas or have fixed something like this before...
Thanks Again
Old Dec 12, 2010 | 04:15 PM
What?
your original idea seems fine, or try this stuff...
Advance Auto Parts: PermaPoxy™ 5 Minute Plastic Weld by Permatex - Part 84115
Old Dec 12, 2010 | 04:20 PM
89 2.3 91 SSP 5.0
Do you guys think that stuff will hold up and not crack when I bolt the bumper cover back on?
Old Dec 12, 2010 | 06:46 PM
purple87lx's Avatar
Yeah, use that just sand it with 80 grit to give it something to bite to then let it cure drill your hole sand off the access then prime and paint if you want.
Old Dec 13, 2010 | 07:25 AM
89 2.3 91 SSP 5.0
not sure if there is enough stuff in the tube to cover the hole and make it thick enough to sand and still be strong....I will figure it out....
Thanks to those who replied and if anyone else has done this before please feel free to make a suggestion!!!
