help needed asap!
Ok so my 90 mustang gt has a problem, it was making a slight tapping sound for a week or so then I changed the oil and it went away. So then a month later (now) its making a loud tapping sound. So I took the intake and valve covers off to check the pushrods/ lifters. And nothing is bent or broken. So what can it be. The motor is a fresh rerbuilt 5.0 with about 5,000-6,000 miles on it. So any help please! Thank you.
More info on the sound is required please. Do you have solid lifters? Or hydraulic? Are the heads rebuilt, new, or old? The rocker arms...are they new or old? Also, are the rollers? Or stock ball and socket ones etc etc.
I am inclined to think they are stock ones that are ball and socket type. And if so, you may simply have a bad rocker arm.
It happened to me once....and when I replaced the rockers, poof....The tapping went away. Hope this helps.
If you had a collapsed lifter, like Tommy said, the rocker would be loose, and no way to tighten it up.
Is your valvetrain adjustable? (You said it's stock, which would indicate it's not....buuut....) I would like to listen to it sometime, but unfortunately, I am training this morning, and then this afternoon, I have a lunch date with a new girl.
Who did the rebuild? Were the heads rebuilt also? Did they just do the short block? Or the long block?
