Crank Pulley leaking oil ???
Hey any of you guys with pullies. I put mine on about 2 weeks ago, and have noticed a very small amount of oil that seems to be coming from behind the pulley. I'm guessing I wasn't liberal enough with the gasket maker in the keyway, but wanted to see if anyone agreed/disagreed with me before I go fight that damn crank bolt and bitch the pulley off the crank.
I used a dab in the keyway as the installation calls for. Any suggestions on how much to use the second time around?
Well, I just fought that damned bolt by hand... (I've got air tools, but my impact wrench is too big to fit in there unless I take the radiator out... which I am NOT doing). Pulled it off, and had oil inside the pulley behind the timing adjuster, so I'm figuring the keyway is the culprit. I loaded it up with RVT silicone, so hopefully it will hold.
Originally posted by "FordMan"
:o :o :o :o
Oh god not another mod block getting rady to take a dive !
:o :o :o :o
Lets see you put 12#s of boost into your motor and see if it blows. So don't hate on the mod motors we just like to live on the edge.
Does that look normal to you?
Well, I redid it last night, so hopefully the leak is gone. When I got the timing adjuster off, I had a nice little pool of oil sitting inside the pulley, so I'm pretty sure it was me not being liberal enough with the RVT in the first place. The instructions said a 'dab', so i used a dab... This time, I filled all but the last 1/8 inch of the keyway.
Maybe I should have packed it with RVT too...
yeah, it was torqued properly (actualy 99+ has a different torquing procedure. torque to x. back off 1 turn torque to y. torque an additional 90*) or something like that. It's in the garage and I'm not, so......
It was definitely me being too conservative in the keyway. I got the timing adjuster off and had oil sitting in there (not much, but a little).
It hasn't leaked yet since I redid it, so I think it's fixed. I'll keep an eye on it for a hile though.
