vibration problem
Old Aug 6, 2002 | 07:15 PM
stangerang's Avatar
whoopdy fucking do!
Default vibration problem
my car is vibrating really rough when slowing down (clutch in) and idle, when i give it gas it is fine, i ca feel it alot in my seat and shifter....
im guessing tranny mount??? any oter suggestions or anyone experienced this before??
thanks!
200 points away from a 300
Old Aug 6, 2002 | 08:29 PM
Hondahunter97GT's Avatar
Red Stripe Beer!
Originally posted by "FordMan"
Damn POS 4.6 L !
You had better find it soon because you are fagging out on me for this Sunday !
I would venture to say tranny mount or u-joint.
I cant believe u said that Scott
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
Old Aug 6, 2002 | 08:46 PM
Road Rage's Avatar
Shake n' Bake
Slowing down?? I would say your rotors, maybe?
Old Aug 6, 2002 | 09:22 PM
4.6Power's Avatar
The H N I C
who cares about slowing down.....how does it acclerate? that is all that matters
anyway my bet would be on the u-joint
Does that look normal to you?
Old Aug 7, 2002 | 05:17 AM
DrDirt's Avatar
Team Geritol Racing
Not sure what type of vibration you mean but check your tires. Sometimes when the belts start to separate, it will cause the car to shake and wiggle as you're coming to a stop. Get with a buddy and swap out the tires for a test drive and see if that clears it up.
Tony
Old Aug 7, 2002 | 05:56 AM
Toma's Avatar
Ricer In Training
It's gotta be either your CV joints or distributor
You changed the fuckin mouts like less than 6 months ago
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Old Aug 7, 2002 | 07:08 AM
5SlowRacer's Avatar
~ST0N3D~
I had a bad vibration when I was slowing down and at about 65-75 mph took it to Ramsey's Performance they changed my u-joints. Still had a vibe slowing down and at 65-75 jacked my car up and spun the tires and they said I had a bent left axle. Time for a rear end upgrade now.
How cheap can anyone get an 8.8? installed?
85' Mustang GT 5.0 $1500 obo!!!
03 FOCUS ZX3
NICK
Old Aug 7, 2002 | 07:58 AM
stangerang's Avatar
whoopdy fucking do!
not under braking just when the motor is not engaged.... it does it slightly at idle when you first stop, then after you sit for a minute it is gone.....
u joints huh????
BTW: i will still run it, nothings broke.... (YET)
alcohollica, i replaced the motor mounts..... they are fine still...... especially with that brand new motor sitting on them
