A/C Questions
hey guys i am trying to buy 03 GT but theres a problem with the a/c, ok so the a/c blows but the heat doesnt work, and from what i can tell there is a line off from the intake manifold where does the line go, what could it be??? thanks..
((Get Staggered))
((Get Staggered))
possible blend air door actuator stuck, Im trying to remember what year ford switched from vaccum to electric operated a/c box. I know 01 pickups have the electric actuators. Not sure on the mustangs, Does it switch from vent, to defrost?
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
the blend air door actuator ( hot to cold ) is on the bottom of the a/c box, and its a little bit of a PIA to get to to change out, because it has a rod made into it. And it goes in from the BOTTOM! They are notroious for freezing up, on the F-150s and Expeditions...
true story, but when winter rolls around i am gonna want it you know... plus when you spend around 8gs for a car you want everything to work right...
((Get Staggered))
((Get Staggered))
